Speedo wrong
Old May 30, 2018 | 09:45 AM
Bigdade's Avatar
Bigdade
Default Speedo wrong
I have a 1980 C3 the speedometer is 10 miles an hour to fast I have a 19 tooth gear coming out of the tranny if I bump it up to 22 or 21 will that fix the problem
Old May 30, 2018 | 10:55 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
1 tooth is typically a 5 mph change. Below is the original gear chart from GM.
But did someone do some work on the tranny and possibly change the drive gear..... Or is the speedo just losing it's magnetism? Since the 1980 cars only used the 19 tooth driven gear for all combinations I'd probably take a look at the speedo as being the culprit vs the gear in the tranny.
Willcox
Old May 31, 2018 | 09:28 AM
derekderek's Avatar
derekderek
Don't speedos read slower as they de-magnetize, not faster?
Old May 31, 2018 | 09:33 AM
shaun8484's Avatar
shaun8484
I was wondering the same thing, mine tends to be about 5-8 mph faster once I get about 25 or so.
Old May 31, 2018 | 01:35 PM
Bigdade's Avatar
Bigdade
I will have to check into a new speedo then.Thank you
[/QUOTE]
Old May 31, 2018 | 01:39 PM
Bigdade's Avatar
Bigdade
I’m just concerned it’s putting mileage on the car faster.
Old May 31, 2018 | 04:16 PM
derekderek's Avatar
derekderek
Speedo reads too fast. When you go down the interstate, does odometer match mile markers, or put 11 or 12 miles on in 10 miles? Cuz the odometer is cable driven. If it reads high-or low-the gear ratio between odometer and wheels is off.
To Speedo wrong
