1970 Brake Problems
Old Jun 5, 2018 | 10:47 PM
cagotzmann's Avatar
cagotzmann
Originally Posted by Fredtoo
It would be nice if someone with a Wilwood master could look at theirs and see if the "push back" of fluid into the reservoir is even or staggered.
I have a wildwood MC and its very difficult to see any flow "push back", but when there is air in the MC you will see air bubbles start via the holes as soon as I press on the brakes, equal front vs back. Also when I pressurize the MC brakes apply front and rear at the same time. I don't have any tools to measure the actual pressure at the pads so I don't know what the actual force is (proportional or not).
Old Jun 6, 2018 | 09:34 AM
DUB's Avatar
DUB
I am sorry that I did not clarify that when I am looking in and watching the piston of the master cylinder I am dealing with the original design cast iron dual reservoir master cylinder.
As for being able to test the actual pressure at the caliper. This gauge and fittings can be purchased if desired more than likely from Willwood or get one like I did from Master Power Brakes.
DUB
Old Jun 6, 2018 | 12:36 PM
Fredtoo's Avatar
Fredtoo
Thanks the the input
To clarify, when looking at the bubbles, do both compensation ports close off at exactly the same time?
It would make sense if they did.
and.......
How does the fluid 'push back" compare to a GM master?
I know from racing m/c, the less push back, the better the feel of the brake lever.
Old Jun 6, 2018 | 02:47 PM
bill69's Avatar
bill69
So last night I plugged the rear port of the MC and left the front port connected to the brake line. The break pedal was rock hard, or really really firm. I assume this means two things, the MC is good, and the front brakes have no air in them. I also assume this means the MC doesn't have any or any significant air in it? So I guess I just somehow got a large amount of air in the rear lines, not sure how, that I will have to somehow remove.
Old Jun 6, 2018 | 09:14 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
maybe do some gravity bleeding of the rear brakes ....sit back and have a beverage or two then bleed them.
Old Jun 25, 2018 | 01:41 PM
bill69's Avatar
bill69
Turns out the issue was the drivers side rear caliper. It was sealing under pressure and letting air in when it wasn't under pressure. I used some vice grips on the flexible lines to block them off and isolate the problem. Wish I would have done that earlier.
Old Jun 25, 2018 | 08:52 PM
bobs77vet's Avatar
bobs77vet
and that's exactly why mity vacs don't work on lip seal calipers.....found that out the hard way
