350ci motor
Old Jun 4, 2018 | 06:29 PM
jacob.o's Avatar
jacob.o
2nd Gear
Default 350ci motor
crankshaft bearing went bad after 3000 mi.
engine is full mod , around 400hp.
will it be smart to cleen rod surface on crank and go oversize bearings?
i thank you
jacob
Old Jun 4, 2018 | 06:33 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
i thank you
jacob
Did the bearing get grooved? What happened to it? Are there gouges or marks on the crank. If the engine is in and the crank is fine just replace the bearings. Otherwise you will have to pull motor and have the crank machined .010 or .020 and get all new bearings that size.
Old Jun 4, 2018 | 06:39 PM
lbzraptor's Avatar
lbzraptor
Is the rod itself ok? How bad is the crank? If the crank is to bad to polish I would remove the crank and have the journals turned and leave the mains alone. Any idea what caused the bearing to go bad? Also maybe I am misunderstanding, is it the crank/main bearings or a rod bearing?
Old Jun 4, 2018 | 06:43 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you need to go to a machine shop that you trust and has a good reputation for advice on this
Old Jun 4, 2018 | 06:48 PM
derekderek's Avatar
derekderek
look on the back of the bearing shell. it will say STD, 010, 020, etc. buy a bearing that size, clean up crank journal install it and plastigauge it. but if bearing went bad, something is wrong with something. a size is off, bad oil feed, something. I have replaced bearings and had motors live. about 50%.
Old Jun 4, 2018 | 06:53 PM
bobs77vet's Avatar
bobs77vet
but if bearing went bad, something is wrong with something. .
that's what my point was ....somethings not right....you need to have some one put eyes and hands on it who knows what they are doing. so this doesn't happen again.
Old Jun 4, 2018 | 06:57 PM
BlackC3vette's Avatar
BlackC3vette
i thank you
jacob
What was the cause of the bearing failure? Was it the mains?, rods? or both.
Without finding the cause of the failure, the same thing will probably happen again.
To 350ci motor
