Comp Cam
Old Jun 20, 2018 | 08:47 AM
REELAV8R's Avatar
REELAV8R
Originally Posted by bugzbunny
I thought anything lower then 110LSA you lose vaccum?
well the 108 advantage is on the induction side of the events. It creates a slightly better pressure reduction during the intake phase to suck in more fuel/air.
the down side, can be idle quality. I happen to like a slightly lumpy idle. It does take a little tuning and perhaps a fairly good ignition lead due to the low cylinder pressures at idle, but I feel the strong mid range and slight extension of the top end rpm is worth the price. For the same duration .the 108 offers slightly more overlap. Get a nice high lift cam ( relatively) and it can take a bigger gulp of the intake charge.
my vacuum at 800 rpm is 14" on most days this is at 3500 feet. So at sea level it would be slightly higher. Even in gear it's about 11" still plenty to run the brakes and all the vacuum accessories.
Old Jun 20, 2018 | 08:56 AM
ZEN357's Avatar
ZEN357
Comp Cams make some of the best you can buy. You won't go wrong with them.
Old Jun 20, 2018 | 12:28 PM
BKbroiler's Avatar
BKbroiler
Originally Posted by mobird
My earlier comment about getting his car dynoed (directed at jb78) was pointed at him quoting his car having 440-450 hp all the time, which to me is just a shot in the dark based on what some other motors have done with similar parts. It always twists my gut a little to see people saying "my motor makes xxx horsepower!" when they have not tested it at all, how do you KNOW it makes that power? It is far more impressive to me to see a lower dyno-proven number than an inflated Gross horsepower guess.
This is similar to people claiming they have a 10 second car or an 11 second car when they've never been to the track.
Old Jun 20, 2018 | 01:15 PM
jim2527's Avatar
jim2527
As other have said it comes down to properly matching heads/cam/intake/compression etc.
If you look through GM, Edelbrock and Trickflows 'crate/top end' packages you'll get a good idea of what it takes to get 4XX hp. Surprisingly the GM ZZ4 cam or a 'cheater' version of it can get you 500+hp. There are a lot of threads on Speedtalk about modifying the 604 crate engine which uses the ZZ4 cam.....
Call Straub or Mike Jones....
Old Jun 20, 2018 | 01:42 PM
jb78L-82's Avatar
jb78L-82
Yup the only true way to know is to dyno the engine which I did not do BUT the guy who built the bottom end of my L-82 355 who does ONLY GM engine builds/upgrades/PCM tunes etc exclusively, old and new, including the new Z06 LT-4 etc confirmed my combo based on his real world experience building this exact same motor with my combination of parts and dyno proven in HIS shop is good for at least 425+ Gross HP without my headers. I can assure you he has built more Gen 1 motors than most on this forum and I trust his judgement and comments about my engine. Getting a fairly close estimate to what a particular motor will make with said components is NOT rocket science..not even close!
PLUS, there literally article after article of SBC Gen 1 355 builds with AFR 180 heads and very similar cams to my Howards Roller cam specs with LESS compression making an easy 425 Gross HP dyno numbers. Here is just one:
http://www.superchevy.com/how-to/148...-engine-build/
Finally, I have raced a few sedans and formula cars in my experience and know HP versus weight and what it feels like with certain HP levels...I really don't care about a dyno number for my engine, personally, and not so sure why some are wound up about an estimate for MY engine. The 505 Net HP in my 10 C6Z06 with 3,100lbs weight also gives my a good comparator for the 78 C3.
Just to be clear, since I have all ready spent way too much time explaining for something I should not have to explain, my Gross HP number I did not just make up............It is my estimate based on more than a few parameters. Makes zero difference to me if you buy that number or not............
Old Jun 20, 2018 | 03:00 PM
mobird's Avatar
mobird
A couple things I would like to comment on that. One is Gross HP vs Net HP. No one quotes Gross HP on a modern car (as I'm sure you know), so comparing your "estimated" gross hp to a modern cars net hp just sounds like inflating the numbers on your motor to sound good, in my opinion.
Not caring about a dyno number (as you say) is all well and good, but then why quote horsepower numbers for your motor? And along those lines, I see you quote "425+" and "440-450". There is a 25 horsepower swing in there, which again to anyone with knowledge of engines just sounds like throwing numbers out there.
And while I can respect the "butt dyno" of having driven multiple cars at different power levels, it is far from an accurate measure. My C3 FEELS significantly faster than my brother's 2016 STI (which has a dyno proven 402 whp on an AWD dyno), but in reality his car pulls on me a bit. Comparing one car to another and saying your C3 FEELS as fast as a Z06 and therefore has to be making a certain power level (I realize you are not saying that, just using the cars in your example) is no different than when teenagers do "ricer math" and say "I beat car A, and car A beat car B, therefore I must have X power and be faster than car B!".
All I'm saying is, your estimate is based on what a magazine article (using different components than you and has a vested interest in making a good power number) and an engine builder (who DEFINITELY has a vested interest in telling you a good power number) have said your engine should make. Why not prove it so you can tell people the number your motor makes? Or if, as you say, you don't care about dyno numbers, why quote numbers that you haven't proven with your motor?
I know this is the internet and my comments might be taken as insulting, so trust me when I say I don't mean to be offensive or rude to you. All of this is stuff I would say to a friend over a beer.
Old Jun 20, 2018 | 03:44 PM
jb78L-82's Avatar
jb78L-82
All good...point made and understood. Difference of opinion is OK by me, no offense taken.
Old Jun 20, 2018 | 03:50 PM
mobird's Avatar
mobird
Cool deal.
And for the record, I'm jealous of your AFR heads and roller cam! I'm hoping to have more power under the hood soon, and I've been flip flopping between trying to make my Gen 1 as good as I can make it (within reason) and put a nice retro-roller setup and some higher compression pistons in, or just say screw it and start working on converting to fuel injection and run an LS motor. Got my Quadrajet running so good after an extensive overhaul (courtesy of alot of new carb knowledge from Cliff Ruggle's book) that fuel injection seems less important now...
Old Jun 20, 2018 | 06:12 PM
jim2527's Avatar
jim2527
There's a pile of parts and garage mechanic like myself puts them together properly it'll get XYZ hp. If a professional puts them together its get XYZ+ hp. Unless you do something ridiculously wrong it'd be impossible not to hit that XYZ number. Hence the range...
I think most of here, if asked, could whip up a 400hp 350 without thinking too hard. Flat top pistons, 170cc+ small chamber heads, performer RPM intake and an off the shelf roller cam. How could you not get 400 out of that?
Old Jun 20, 2018 | 09:00 PM
bugzbunny's Avatar
bugzbunny
Originally Posted by Sigforty
you’re lsa is determined by the valve events. Having the proper valve events is most important.
Also another thing to think about is Inches of vacuum, This may be of concern if you have vacuum assisted accessories, such as power brakes or steering. A cam with a 112* lobe center will pull approximately 16-20" of vacuum, which is good for power brakes. A cam with 110* lobe center approximately 14-18", is borderline. However a cam with 108* will only pull 12-16", which is not enough for power assisted accessories.
Old Jun 20, 2018 | 09:09 PM
REELAV8R's Avatar
REELAV8R
11-0
I’m running 10.6:1 with my 270 cam. At sea level this would put me at a 8.81:1 dynamic ratio. However at 3500 feet it reduces it to 8.11. This is a manageable ratio that is not particularly prone to detonation.
use this calaculator to determine you dynamic CR with various cam specs.
http://www.jeepstrokers.com/forum/calculator/
at at a true 11:1 CR , actually measured, not assumed, the quench will have to be spot on that means near to .040” as you can get or slightly less depending on clearance with the valves. A good cooling system and good mixture control along with proper timing to avoid detonation issues on pump fuel.
i can actually run 87 octane with no detonation issues, but usually run 91 to avoid ethanol. My quench is at .038” with AFR heads angle milled down to 55.5 ccs. and still have valve clearance.
since your block has been bored it may be zero decked as well, something that will have to be known to get proper head gaskets for that quench.
For example, I put in a 280 cam on a 108 with 7 cc flat tops with your 4.060 bore and came up with a 10.28CR and a dynamic of 8.28 at sea level.
285 cam gives an 8.1 DCR.
play around with the calculator see what you come up with.
not sure how you are getting 11:1 what pistons, and chamber volume you using?
Old Jun 20, 2018 | 09:17 PM
REELAV8R's Avatar
REELAV8R
all my stuff works at 11” of vacuum. Lights, vents, brakes, etc.
well the vacuum advance did have to be altered to accommodate the low idle vacuum.
but if it concerns you get a 110 LSA
Old Jun 20, 2018 | 10:52 PM
  #33
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Your numbers are off. Most power brakes will run at 10" and some cases lower. It really depends on the booster and setup in the car. The vettes also have a tank that stores vacuum. If your system is in good shape you will not have issues. Additionally, you don't just look at lsa. I mentioned before you have to look at the valve events the engine wants. A higher Lsa cam may have shorter duration, and that will help build vacuum compared to a longer duration higher lsa. People often make the mistake of using too much duration and buying off the shelf cams. Something more tailored to your combo will be better.
Old Jun 21, 2018 | 04:54 PM
  #34
bugzbunny's Avatar
bugzbunny
Wow so much to learn. Thank you, all you men sure know your stuff. My car is probable at 10.25. I also live in Arizona, which sea level here is close to zero. Never had a issue with gas here. Last build it was all stock put back in car. Except manifold and carb. It will not be a daily driver and am a firm believer in new technology and the fact I can let it sit without starting her for awhile, plus looking for more HP. Basco Engines in Gilbert is the one rebuilding. They have a great reputation and have built many race cars. My heads are cracked so those are out and the cam had some flat spots, so we are doing a complete rebuild. He is taken and giving advice and wanted to go with a kit cam, but after talking with you I thought a Lunati Cam and rollers would be a better choice. I hear so many different opinions that it makes my head rattle. It's already up to $6,000 including Dyno testing just to get it spot on. Was hoping not to go much more then this, but we all know how that goes. Thank you so much again, I love this forum.
Old Jun 21, 2018 | 08:10 PM
  #35
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
What? I'm sorry sir, but you are off a bit on this. Gilbert isn't close to zero in elevation, at least not in my part of Gilbert. The elevation here is 1,237' above sea level. As far as Basco's goes, I would NEVER let them change my oil let alone touch my motor. I can tell you first hand experience with that shop and ole Ray Ray and how they completely destroyed my numbers matching block and much more. Good luck with your motor build and hope it lasts, a better choice would have been WFO Racing in Phx. He does all of Cordes Performance Racing motors exclusively. Kelly over at WFO knows a ton about motor builds and also happens to race on the new TV show No Prep Kings which is a spin off from Street Outlaws. He will be racing his own car this season on that show. Kelley runs a Dart 800 cu in BB with 4 kits and looks like a plumbers nightmare and hauls ***.
Old Jun 22, 2018 | 05:44 AM
  #36
PainfullySlow's Avatar
PainfullySlow
Dyno runs for a hp/tq printout are for those who need bragging rights.
Those who don't Need To Know, usually don't care and don't feel the need to bost.
I've dyno tuned a couple of my motorcycles with EFI just to get them spot on and tune the best performance out of the machine, but never even asked what the motor put out or collected the dyno sheets.
I probably won't dyno my 496 either.
It really won't matter what it puts out as long as it runs good, strong and is dependable.
I guess that depends on the use of the motor. I couldn't care less what power my street car makes but as a racer I dyno'd every single motor I built (multiple times throughout the year as conditions change) not only for tuning but also to see that graph so I know exactly where the torque and HP curves are so that I can optimize the starting RPM for my launch. It also serves as a benchmark for wear so I know when the motor starts to drop in HP that I will need a rebuild.
Just tossing another view out there.
Anyway, back to the OP: I have run Comp cams in the past and chose to go with them in my current build because it is a company that I know and have had good luck with. While I agree that there are a lot of quality cam companies out there I think there is a general 'elitism' on this board in general; my corvette is special so I need a special cam.
While I don't begrudge anyone that attitude and absolutely believe that 'to each their own', I think you will find that any 'production' company here tends to take a back seat to the boutique shops in terms of public opinion. I suppose if I were looking to squeak every drop of power out of a mill that I would be more picky in my choice however, like you, I am putting together a pretty mild motor by today's standards and just want something that will provide decent power, sound good, and not break. I feel that Comp meets all those requirements.
In the end the choice is yours.
Old Jun 22, 2018 | 07:25 AM
  #37
A8skyhawk's Avatar
A8skyhawk
Good discussions above for sure. For what it’s worth I built a similar engine to the final one in this article and have been very happy. One day I would like to get it on a dyno just to see what I have:
Sallee Chevrolet used to offer a “Super Sallee Chevy ZZ4” back in the day that I can’t seem to find the old specs for at this time. They ended up with AFR 195s (angle milled to 58cc for ~10.1 comp.) with the hot cam kit and put out pretty impressive numbers.
Just to add my 0.02 cents to the above, I think it’s ok and appropriate to call a very street friendly Chevy 350-355 that makes solidly in the 400s/400s a beast. Sure you can get there as well with a 383, but then you can get a lot more as well (something about no replacement for displacement and such). I find the fun is in optimizing the performance around the given displacement (overall performance that is still drivable) .
To Comp Cam
Old Jun 22, 2018 | 12:54 PM
  #38
bugzbunny's Avatar
bugzbunny
Didn't mean to offend you, was just saying almost zero and Ray is long gone. WOW
Old Jun 22, 2018 | 12:56 PM
  #39
bugzbunny's Avatar
bugzbunny
Thank you
Old Jun 22, 2018 | 12:58 PM
  #40
bugzbunny's Avatar
bugzbunny
Agree thank you
