Already done with ram.First one bound up.Second wont pull itself out of garage. New billet flywheel. New everything. What are you running and are you happy with it.Ram customer service sucks so dont even go there.My car 71 350 4spd stock.Bored and 510 in lift cam.
They been around a long time. Leaning towards that one.Anybody else.First ram I bought they included wrong throw out bearing.This is the 3rd time Ive had it out.Went ahead and completely rebuilt trans this time.
I have read they have that problem with c.f.,Which McLeod did you go with,I'm having the devil getting a clutch that works,Ram screwed me for the last time,first one bought as kit,had wrong throw out bearing,After installing it it bound up so bad pulled it.Gave them one more try,Second one turned wheels on jack stands but slipped so bad wouldn't pull car on ground,Brand new billet flywheel as well,.I have never had a problem with a clutch before,Put it in and it goes,
I use SPEC clutches and flywheels. They are built to very tight tolerances and not just to 'Detroit specs'. Which the engine builder I use when balancing the crankshaft verified. Many of the others listed were too far out of spec to work and when the SPEC one was given to the crankshaft balancer guy ...he was amazed on how well it worked out.
