I was considering welding disks into my diff crossmember and mounting it solid, but I saw this set from vansteel and wondered if anyone had an opinion on it. Thanks https://www.vansteel.com/index.cfm?f...p=3031&ID=3904
I have heard of solid steel mounts....but this kit seems to be a quality product for the price.
But one would have to wonder if the car is driven on the street respectfully if this is really needed at all. I know improvements have been made on the suspension for the Corvette over the years. But some of these improvements may not be fully utilized if the car is just a cruiser. Jjust saying.
I don't think that I paid $50 bucks for two aluminum disks and two grade 8 bolts. The Delrin kit you posted might be slightly more ridged than the crusty old original rubber. But that is kind of a moot point because mechanically it is held ridged by the metal on metal contact. I ground the bottom of the diff cross member flat where the disks bolt on.
BUB, you must not have a very powerful vette, quality tires, or a manual tranny! Vettes get violent wheel hop. When I first converted from auto to manual I couldn't give my vette very much throttle in the first two gears.
The other thing is to get an aluminum or poly differential snubber bushing.
I probably should have mentioned. This set also raises the differential a bit which is also a goal.
I would ask them how much it actually raises the diff. I just put in a new 4.11 diff. The only way to gain some height would be to change the end cones on the frame that fit into the end mounting holes in the cross-m. some of the c-3 track vettes had actually modded the cross-m and they were moving the diff up about an inch. but they had big fender flairs to accommodate big tires riding closer to the frame
Actually the Van Steel rear diff Derlin kit lowers the rear of the car 3/4" to 1" by raising the differential up into the frame and it may be better than adding longer spring bolts.
gkull and DUB are both correct, it stiffens the rear and gives a more solid ride but may not be necessary for a corvette basically driven as a cruiser on the street.
I'm installing it on my 73 with the full coil over conversion kit and looking for a very aggressive suspension.
I would contact Van Steel and talk with their customer service reps before you purchase.
I just installed the Van Steel Kit on my 71. I don't have any input on how it works yet because I am still neck deep in getting things back together on my body off resto. The kit goes together easy. I have a lot of experience with Delrin in my aerospace manufacturing background and I can say it is a very rugged material yet still stays somewhat malleable to dampen vibration better than metal on metal.
If the differential is bolted to the rear crossmember, how is the front differential support going to raise or lower the differential?
I'm not sure I understand exactly what you are asking. In order to raise the differential or lower the frame you must modify how the rear cross member mounts to the frame as well as the front mount. I am guessing the kit from van steel uses a shorter or thinner bushings for the cross member which will raise the differential, the front mount would need a thinner bushing as well in order to maintain the pinion angle.
