side pipe exhaust insulation install
Old Jul 3, 2018 | 03:29 PM
dmaxx3500's Avatar
dmaxx3500
Default side pipe exhaust insulation install
anybody have any pics on the install of foil-backed insulation on the frame rails ,it needs to go on before the body gets dropped back on,
and the foam at the back of each frame rail in the rear wheel-well opening
Old Jul 3, 2018 | 03:34 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I’m not aware of the foil backed insulation. I’ll be interested in what others post.
Old Jul 3, 2018 | 04:09 PM
Hammerhead Fred's Avatar
Hammerhead Fred
See if these help:
https://www.corvetteforum.com/forums...nsulation.html
https://www.corvetteforum.com/forums...questions.html
Old Jul 4, 2018 | 11:41 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I didnt use those pieces and I dont have heat problems from the side exhaust....my .02
Old Jul 9, 2018 | 10:09 AM
DEITIM's Avatar
0DEITIM
Former Vendor
Hi Tim from DEI here. Just throwing this out there. We offer our Floor and Tunnel II material. It is a dimpled aluminum facing with a glass fiber poly blend backing with a peel and stick pressure sensitive adhesive backing. It will fold, bend, and hold whatever shape you put it in. It also cuts fairly easy with heavy duty scissors or tin snips. Check it out at http://designengineering.com/floor-t...e-heat-shield/ It can be purchased from Corvette Central or Zip Products. Please let me know if anyone has any questions.
Thanks, Tim
Old Jul 9, 2018 | 02:03 PM
dmaxx3500's Avatar
dmaxx3500
problem is I bought the factory looking stuff already,id like to use what I have,i just could use a few pics of what it looks like installed -before I drop the body back on the frame
To side pipe exhaust insulation install
