Determining engine year
Old Jul 6, 2018 | 03:05 PM
titanle's Avatar
titanle
Default Determining engine year
Hi guys
Can you tell me how to figure out exactly what year of engine is in my car? As per PO, it is a 70s SBC350 but I would like to be sure of exactly what it is in case I need to order parts for it etc.
Old Jul 6, 2018 | 04:08 PM
PAmotorman's Avatar
PAmotorman
Originally Posted by titanle
Hi guys
what is stamped on the block stamp pad in front of the pass side cylinder head
Old Jul 6, 2018 | 10:42 PM
A88FXRS's Avatar
A88FXRS
need casting numbers / pad id stamping / date codes on rear of block
Old Jul 6, 2018 | 10:56 PM
lars's Avatar
lars
The casting date of the engine block is cast into the block in the ledge behind the distributor, above the bellhousing parting surface. Date codes are a letter (from "A" thru "L"), 1 or 2 digits for the day of the month, and 1 digit for the year. Thus a 327 with a casting date of J257 would be October 25, 1967. If it was a 350, it would be 1977.
The stamped numbers on the engine ID pad on the passenger side block deck surface just below the cylinder head gasket have the actual date that the engine was assembled. A typical stamp on the ID pad may look like this:
6113797 F0113HP
The first digit “6” means that the engine is a 1966 model year engine.
113797 is the VIN number of the vehicle it was installed in.
“F” means the engine was assembled at the Flint Michigan Plant. Corvette engines were built in Flint.
0113 is the date is was assembled, which means it was assembled on January 13th, 1966.
"HP" is the engine code, identifying this as a 350 horse 327 "L79."
Old Jul 7, 2018 | 10:31 AM
derekderek's Avatar
derekderek
as helpful as Lars is, he probably didn't guess your engine correctly. this site has a very good list of small block engine codes. http://www.nastyz28.com/sbchevy/sblock.html
Old Jul 7, 2018 | 11:00 AM
lars's Avatar
lars
I wasn't trying to guess the engine - I was providing examples of the date code system used on Chevy engines and showing how to interpret the numbers and letters. The numbers in my post above are only used as an example to show how you can determine the date.
Lars
Old Jul 7, 2018 | 05:44 PM
derekderek's Avatar
derekderek
Lars
i knew you weren't. joking way to say here is where you find the codes...
Old Jul 10, 2018 | 12:31 PM
titanle's Avatar
titanle
THanks for all the help!!!
Old Jul 10, 2018 | 11:57 PM
titanle's Avatar
titanle
Here are pics I took of the engine. I can’t really make out what it says in the first picture. It looks like 397014? Any help identifying the engine would be appreciated. Thanks.
Old Jul 11, 2018 | 07:46 AM
maj75's Avatar
maj75
Still need a picture of the flat pad on the block, below the passenger side cylinder head. That is where the numbers are stamped that will tell you what the engine is. Casting numbers are too generic.
Old Jul 11, 2018 | 08:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by maj75
...Still need a picture of the flat pad on the block...
True. What is on the block pad? 3965577 is a Corvette intake manifold. You can Google GM part numbers.
Old Jul 14, 2018 | 09:55 AM
EarlyC34me's Avatar
EarlyC34me
Parts Sherpa
That's a jan 27 1971 block cast at towanda
You can tell by the two digit year and 014 block cast number
Old Jul 14, 2018 | 10:18 PM
titanle's Avatar
titanle
Thank you.
I can't really see the block pad, the alternator is mounted on the passenger side and its blocking that part of the engine.
To Determining engine year
