One Wheel Locked Up
Within the last 2 years, I have dealt with a a frozen rear caliper on my Chrysler 300 (sits out doors) and a friend;s Ford Expedition with a frozen caliper. Also, about to replace the front calipers on my daughter's 01 Grand Prix (210,000 miles and sits outdoors) that is partially frozen.
I would inspect the caliper carefully, change the brake fluid completely,and replace all rubber lines with SS braided hoses which I have had on my 78 C3 since the early 90's. I have SS braided lines on my Chrysler 300....gives a much firmer linear brake pedal than the ruibber hoses....
The better, nicer businesses would include one mounting clip and one copper washer for the front hose only. So, its back to the store for two copper washers and two clips. You can not / should not re-use the washers.
Make sure the copper washers are for brakelines (crush) and not thicker units for something else.
If anyone happens to know a NAPA or Advance Auto part number for the clip and washer, I'd appreciate it. Autozone is close by, too. Thanks--
ZRX
I too bought a brake hose from NAPA and the washer was not in the box. They said it should have been so found another. No part number though.
Try NAPA-On-Line for numbers.
These are the clips that hold the one rubber hose end to the frame bracket. You should be able to reuse the original clips if they are still in good shape. Use pliers to pull the retaining clip out, but break loose the end of the metal line first. Use a fitting wrench not just an open end so the fitting doesn't round off it's corners. This is a Dorman product number and the parts person should be able to cross reference it (I would hope).
https://www.dormanproducts.com/gsear...+Copper+Gasket
Dorman also the crush washers but don't give applications. The inside and outside diameter of the washer needs to be measured to get the correct dorman part number. Honestly, I didn't think this would be so difficult to just find the hydraulic brake hose washers. I am spoiled because I have an drawer with an assortment of them at work. Most parts stores have a Help line that usually has crush washers. Take the new hose and try to match up the correct washer.
Corvette America - http://www.corvetteamerica.com/part-info?partno=27302.
Willcox - https://willcoxcorvette.com/corvette...iece-set-53-82.
Vendors don't list the dorman part number so you don't just take that number to Napa.
The copper crush washers are a generic brake part. All parts stores should have them in various sizes. You just have to match it up to your hose's thread diameter same as you would match up a flat washer to a bolt. Take the hose with you. The one that fits over the hose threads with a minimum of slop is the right one. Buy two or three in case you have to take the caliper back off for any reason. They are not a very expensive item.
Hit the brake line connections with some penetrating oil, opened the Master Cylinder, sucked some old fluid out with a turkey baster, put some new fluid in, closed it back up then proceeded to try to crack the brake line fitting where it meets the brake hose on the driver's side. My 3/8 inch line wrench had a lot of play on the fitting. Thinking it might be my cheap Harbor Freight wrench, I grabbed a 3/8 inch Craftsman open end wrench, just to check the fit, and it had about the same amount of play. Looking closer at the fitting, it doesn't look so hot. Maybe someone grabbed it with vise grips at some point?? Here's a shot of the fitting:
Without replacing that brake line, I'm dead in the water, correct? Unless I too, take a pair of vise grips to it? The line itself looks easy to replace as it's a very short section of line. Also, where the other end attaches to the Switch Assembly, that fitting looks like it hasn't been touched since it came off the factory floor.
What's involved in replacing that line? Does that portion of the Master Cylinder have to be drained? If so, what does that entail, exactly? Do I have to do anything special with the Switch Assembly? Will the brake light come on? Any pitfalls to watch out for? Sorry for all the questions, but I'm a novice at this stuff.
Any advice/suggestions is greatly appreciated.
If you have a good quality flaring tool, You could cut the flare off as close as possible to the flare, pull the damaged nut off and slide a new coupling nut on and make a new flare. Although looking at the picture again, it's so close to a bend, that might not be possible.
I don't see any way of not draining the MC when replacing the lines. But a good flush should be done anyway.
The warning light will only come on if you apply the pedal. Use other means to bleed the system: vacuum, pressure, gravity.
It's gotta come of no matter what so you have nothing to lose by removing it the same way.
It'll likely go right back on via the same tool and just look ugly until you can purchase a replacement.
When you say you think the MC will need to be drained, can I just suck the rest of the fluid out with the turkey baster, or do I need to do something more thorough? Both reservoirs?
I don't know any other way to bleed the brakes, other than the pedal method, although I've seen reference to the gravity method in other threads. Does it make a difference if the pedal is not pushed all the way to the floor during the process? Lastly, has anyone ever written up a step-by-step explanation of how to gravity bleed the brakes? For some reason I thought gravity bleeding was done as a supplement to regular bleeding. Sorry, but this is new to me. I sure do appreciate the help.
The "pump the pedal" method with two people, one opening the bleeder, then the other pushing the pedal ⅓ to ½ way to the floor, then the first closing the bleeder, then the pedal pusher releasing the pedal, also works well. The danger with that method with an old master cylinder is that you never want to push the pedal further than a very hard push with a firm pedal. There's often corrosion and "trash" in the master cylinder that will cut the seals (o-rings) in the master cylinder if you push it all the way down. It's like pushing old rubber seals across sandpaper, and it destroys the seals.
You would be light years ahead by purchasing a little vacuum pump tool now. That tool will also help you with vac leaks on C3s. You can find them on EBay for $20 or so. A even better tool but more money is the Motive Pressure bleeder. Those can also be found "used" on EBay. But you will have to fabricate a fixture that fits over the MC in place of the lid to use it.
Several members swear by gravity method. Its cheap, no fancy tools required, but on the slow side. Some people manage to bleed all six bleeder fittings at one time.
Also, once the MC is drained dry, technically you have to remove it and bench bleed it in a vice or additional issues will haunt you later. You may be able to install a bench bleeding hose kit fitting quickly as you remove the damaged brake line. Those kits come with plastic hose that is routed into the MC That way the MC can not drain. Do not stick a bolt in the port as a plug. You may damage the flare inside.
