Composite leaf, shocks upgrade?
Old Jul 16, 2018 | 08:06 PM
Mitty's Avatar
Mitty
Default Composite leaf, shocks upgrade?
Hi, I’m looking at maybe upgrading the rear leaf on my 74 to a carbon 330lb mono spring, I’ve heard that the shocks can make for a twitchy ride if they’re not upgraded? I have recently new kyb-343218/127 front/back, would these cope?
Also, would my money be better spent on new larger wheels and decent tyres, getting rid of the 15” radial TA’s?
Cheers, Tim.
Old Jul 16, 2018 | 08:31 PM
SI67's Avatar
SI67
If you have stock standard springs up front, that 330#/inch spring will make the rear a lot stiffer. You might get some unbalanced and undesirable handling (oversteer?) that way unless you also put stiffer coils up front.
Old Jul 16, 2018 | 08:46 PM
Mitty's Avatar
Mitty
Right, so a front coil upgrade would be more worthwhile than shocks?
Old Jul 17, 2018 | 04:01 AM
terrys6t8roadster's Avatar
terrys6t8roadster
My 69 got a 330# rear composite spring, when I got the car it had new Monroe gasmatic shocks all around. It rides great. When purchasing the spring I went with the shorter spring for the 18x10 rear wheels. Front is all stock. T
Old Jul 17, 2018 | 07:03 AM
Mitty's Avatar
Mitty
So I guess it’ll be a case of suck it and see.
Is there much difference in the different makes of monosprings?
I see the vb&p mentiond a lot, but their website is suspended? Are they still going?
The zip products leaf is cheap at $369, but are they any good?
The vansteel is a little more at $439.
It’s a little awkward in the U.K., shipping fees, 20% vat on all prices, so want to get it right.
Thanks for your thoughts.
Old Jul 17, 2018 | 08:30 AM
terrys6t8roadster
Check out Van Steel that is where I got my spring from, also get the longer bolt kit. Might be worthwhile to call them, great bunch of guys and good sound advice. I was going to go with a 300# spring but they convinced me that the 330# was the right one and they were right. T
Old Jul 17, 2018 | 07:39 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
15 inch radial TAs give a nice ride....lower profile 17" wheels may not give the ,ride you are looking for
Old Jul 18, 2018 | 02:40 AM
7T1vette's Avatar
7T1vette
Since you have new shocks, install the spring and see how it works. You'll know if the ride or handling is unacceptable to you. If shocks need to be changed, go to Bilstein "Sport" shocks in rear. Bilstein Heavy-Duty shocks are not firm enough with that spring, IMO---too bouncy when you ride over a pronounced bump.
Old Jul 18, 2018 | 08:47 AM
Mitty's Avatar
Mitty
Thanks for the info, it’s nice to see no one advising against the composite rear leaf, so long as it’s complimented with the correct shocks and front springs. I’ve read the bilstien are the shocks to go with.
Old Jul 18, 2018 | 02:34 PM
Primoz's Avatar
Primoz
2017 C3 of Year Finalist
I just purchased a complete EZ ride kit from Van Steel.
Very helpful bunch of guys there at Van Steel!
I also live in Europe and they wanted to get the things right so I went with the package.
Not cheap but worth it because they did all the testing and put together a suspension package that will fit together nicely.
Link to my kit:
http://www.vansteel.com/index.cfm?fu...p=3047&ID=3689
Old Jul 18, 2018 | 02:42 PM
Mitty's Avatar
Mitty
It sucks having to pay import vat. Puts that kit at about £1300, or $1700! Looks like a good setup though.
Old Jul 18, 2018 | 04:52 PM
OMF's Avatar
OMF
Look in the for sale ads on this site....last week there was a VB&P 330 lb spring for sale, it may still be there
Old Jul 23, 2018 | 05:23 PM
LiveryStable's Avatar
LiveryStable
8th Gear
Everyone refers to Bilstein Sport shocks but all I see are performance and performance plus lines....is there a difference?
To Composite leaf, shocks upgrade?
