Horn Issues
Old Jul 23, 2018 | 07:41 PM
collinde's Avatar
collinde
Default Horn Issues
Hi
Recently replaced my turn single on my 1975. Horn worked when pushed before the new switch was installed. Now, when I push the horn button nothing happens but when I turn left or right,the horn goes off.Any idea's??
Old Jul 23, 2018 | 08:28 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by collinde
Hi
Old Jul 24, 2018 | 06:03 PM
DUB's Avatar
DUB
You have obviously something wrong...and not knowing what you did or did not do.,..it is hard to pin point it.
Is this a tele-tilt column?????
Did you replace or make sure you reinstalled the plastic insulator that goes on top of the large U clip you installed when you compressed your lock plate????....if you do have a tele-tilt column.
DUB
Old Jul 24, 2018 | 10:06 PM
collinde's Avatar
collinde
DUB
The plastic insulator is new, not sure if it is in right as I couldn't find a picture of it anywhere. It has a tilt and tele column
Old Jul 25, 2018 | 09:07 AM
DUB's Avatar
DUB
GOOD to know you at least have the plastic insulator on the U clip. Without it...your horn can sound off all the time.
AS for how you built it....unless you can find some information on an exploded view of how it all goes back together.
You can PM me and I can give you my shop number so I talk you through it do to I know the internals of these column very well.
From what you described it seems like the issue is at the horn button area and upper horn contact....so getting back into it will not be that big of a deal and using a Phillips head screw driver may be all you need..
In POST #2 where WILLCOX posted some helpful information. The photo in the upper right corner is where I feel you problem is at.
BUT...how you installed the LOCK PLATE that went on top of your lower horn contract is CRITICAL. The lock plate can go on two ways ...but ONLY one way is correct.
DUB
Old Jul 25, 2018 | 12:16 PM
DavidandJoansVette's Avatar
DavidandJoansVette
Veteran: National Guard
Same topic but different car. I have a 77 L-48. Horn works....sort of. If you lift one side of the button and push the side across from it it will work. push on just one part no go.
shop had it working at about 1 o'clock and 7 o'clock.
something is amiss in the column under the button. The good news is the problem is isolated to the column. Bad news is i have no idea where to start. Suggestions welcome.
Old Jul 25, 2018 | 12:31 PM
0Willcox Corvette
Former Vendor
The issue is in the upper contact.... remove the horn button, remove the three screws that hold the upper contact. Then take a screw driver and touch from the lower contact (shown in my picture above) and see if the horn blow... I'm betting it will. The button is shown in the picture below... Since the horn is hot all the time it's waiting for ground to blow. That aluminum button you see in the picture is the ground.
Now the issue is the aftermarket contacts suck! The retainers for the horn button are not the correct size and this causes issues.
What we typically do is use the aftermarket contacts to rebuild the original. So if you drive the three rivets out of the original and the reproduction contact, then use all the guts from the reproduction but use the horn button retainer from the old contact you can usually fix contact issues and have a contact that will hold the button in place. When you use the old button retainer portion you must make sure it's absolutely clean of rust and debris.... it'll work just fine once re-assembled.
The rivets to take the contact apart are shown in the picture below. If you push hard on the center pin, the rivet will come out... then keep notes on how it came apart so when you re-assemble you'll have it down pat.
Willcox
To Horn Issues
