Easy effort clutch recommendations
Looking to have an easy to mash clutch effort. (Knee issue)
Will definitely go hydraulic rather than stock mechanical Z-bar, etc.
Car will be street driven, with only the occasional 'standing start romp and row' (always in a legal environment obviously). But will not be raced/stripped.
I need recommendation or experiences on brands and levels for:
-"Easy effort" Clutch in actual clutch package
-Are there any hydraulic units that are better than others or do they all generally use and create about the same hydraulic force?
I know this is a bit subjective, but trying to do what I can to make sure I can still drive it when I'm done and some of these things can be brutes.
Thanks for your input.
I'd think you'd want to go with a hydraulic throw-out bearing rather than a fork & slave cylinder. Less points of friction = less effort.
Now also note depending on the transmission you choose with a Twin disc you may get additional noises during idle in neutral gear (clutch out) or gear rattle in a RPM Range during acceleration. This is because twin disc are smaller and don't have any dampening springs in the clutch plates.
Was looking for a way to lessen the effort required and ran across this design. This piece is for 60's Mustangs -but I am working on adapting it to my 71.
http://www.moderndriveline.com/Techn...tch-system.htm
https://www.doityourself.com/stry/wh...w-does-it-work
https://www.carthrottle.com/post/how...ir-importance/
http://www.enginebasics.com/Engine%2...0Cylinder.html
But only if you have enough travel on the pedal, otherwise you won't disengage the clutch all the way even with the pedal on the floor.
- able to change the leverage ratio much easier than a mechanical lever
- overall less friction - but a more minor point
The other main spring in the system is the pressure plate. In my mind this would be the main area to reduce pedal effort: (I'd focus 90% of your energy here.) There is a huge variety here, and many people over-clutch a car. In terms of pedal effort high to low: (due to pressure plate leverage)
- Three finger race clutches
- Diaphragm clutches
- Dual-disc
That's when you could get into changing the leverage pedal ratio, but I would think a previously engineered system would be more than sufficient.
By doing the pedal ratio math you should be able to calculate the pedal force. If someone on here has a similar clutch they may even be able to measure the pedal force for you to confirm. (Hint you don't want my reading on a BB 3 finger clutch)
I also know of local clutch rebuilders who would be willing to put together a one-off custom setup if desired.
My 7500 rpm LT1 had a very light pedal with stock linkage, diaphragm clutch, stock load, and "finger weights" for extra grip at rpm.
Right now I'm using the master that Wilwood recommended for my set-up. I mounted it parallel next to the brake master and reinforced the firewall.
Using the stock location on the pedal only gives me about 2/3's travel to the floor- before the master is at full travel. I made a little bracket for the pedal- to keep the angle correct on the master- I still was bottoming out before it came close to the floor.
I saw that design- had some brackets that BMW used for a remote brake master cylinder laying around and will try it out. Hoping to get full travel of the pedal and lessen the effort a bit. Will cost a lot less then going with twin discs.
TKO 500 - made a spacer to get the throwout just where it needs to be-
Clutch master on the firewall- ½" aluminum plate was used for the mount-
Current bracket on the pedal-
parts I have laying around to make it up -
