Drivers side power window
Anyway thanks for your input.
You wrote this:
When it comes to bolting in the track frame and motor the bolt holes are not even close. My only guess is that the motor drive gear is not in the correct position. I mounted it near the bottom of the regulator gear, maybe I need to bring it closer to the middle
I have no idea of what you are describing...and this does not make sense to me. What are describing is the 'track frame' ???
What are you meaning when you write 'motor drive gear is not in the correct position'
What did you mean when you wrote: I mounted it near the bottom of the regulator gear,..and how can oyu bring it close to the middle as you wrote.
Hopefully the bushing that goes in the center of the plate that aids in holding your motor on the regulator is still there. If you do not have that bushing in that plate...your regulator will fail...QUICKLY.
Also installing a motor on the regulator does take some time due to the bosses on the motor MUST fit into the holes in the regulator so the motor is correctly indexed to the regulator. IF your window motor is missing these bosses...then you can have a problem in the motor wanting to shift and cause the gear to get eaten up.
Hearing a cluck is basically letting me know your gear on the regulator is getting very close to failing . It is easy to tell how badly the gear is worn due to at the ends of the gear on the regulator...you can see what perfectly good teeth look like due to they have never been touched and then look at the teeth on the gear and see how they change shape and can get really sharp and pointed. THAT is when the beginning of the end has occurred and a new gear should be put on if you can do that or buy a new regulator and start fresh.
But even with new regulator they can take a bit of tweaking to get the gear on the motor to be correct to the gear on the regulator so they mesh well and will not wear out due to being spaced too far apart.
DUB
You wrote this:
DUB
Willcox
Willcox
