Wire Identification
Old Aug 14, 2018 | 02:21 PM
red topless gator's Avatar
red topless gator
Default Wire Identification
Can anyone tell me what these wires go to on a 74 W/O A/C? Thanks
Old Aug 14, 2018 | 05:00 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Think the one on the left goes on the sending unit on the head between plugs 6 & 8.
Old Aug 14, 2018 | 10:14 PM
red topless gator
Thanks for the info, can you tell me what the sending unit is for?
Old Aug 15, 2018 | 01:45 AM
7T1vette's Avatar
7T1vette
TCS system, I believe. Transmission Controlled Spark. The sending unit has two temp sensors in it. One is for low temp; the other is for high temp. That TCS system is defeated at cold and hot engine temps; it is only operational with warmed-up engine. You can do a SEARCH on the TCS system and learn all about it. Bottom line: You don't need it (and don't WANT it) unless you live in a state with ruthless EPA testing rules...or...you bleed "green". It was a stop-gap fix for base engines to be able to pass EPA regs without installing the AIR pump.
Old Aug 15, 2018 | 08:50 AM
red topless gator
Thanks for the info, no requirements here in Missouri, don't want it either.
Old Aug 16, 2018 | 09:53 AM
red topless gator
Great help from 7T1vette on green wire, but does anyone have a clue as to what the black connector is for? Thanks, Larry
Old Aug 16, 2018 | 10:32 AM
Peterbuilt's Avatar
Peterbuilt
On the black connector are the wires Yellow & Dark Blue?
If yes then they might be for the washer pump in the wiper motor.
https://docs.google.com/viewer?a=v&p...TRkNTFkY2E0NmM
Old Aug 17, 2018 | 09:35 AM
red topless gator
Thank you very much for the diagrams, will check it out.
To Wire Identification
