Upgrading return line to 3/8"
Old Sep 7, 2018 | 09:59 AM
  #41
lionelhutz's Avatar
lionelhutz
It sounds like you're on the right path. With the bigger line you know it won't cause an issue with the return flow. You can check the sock condition and how clean the tank is too. I assume that's some kind of bulkhead fitting that will seal to the sender unit plate?
Originally Posted by mobird
I saw the picture of the C5 sending unit, and I appreciate the research! But is the C5 sending unit the same as the C3? I guess I was wondering what the relevance is.
To answer your questions. No, the sending units are nothing alike. The relevance might have been to prove the factory pumps have always just used a sock like I posted way back?
Old Sep 7, 2018 | 10:11 AM
  #42
mobird's Avatar
mobird
The sock looks pretty decent to me. The sending unit has a little bit of corrosion, but doesn't look major.
I couldn't find a bulkhead fitting locally (or a good 90 degree one online that didn't have AN threads), so I'm gonna make something work using a threaded NPT fitting. Thinking I'll either drill a hole, or drill and tap a hole with NPT threads and thread it in, and then put a nut and crush washer on the other side. I'll post pictures for sure.
Old Sep 7, 2018 | 10:38 AM
  #43
NewbVetteGuy's Avatar
NewbVetteGuy
Ok I took my fuel sending unit out. FYI, on my 79 I was able to remove it without dropping the tank by removing the fuel door and rubber cover, and then finagling the sending unit out of the fuel door hole.
Plan is to remove the 1/4" return line fitting, and use a 3/8" 90 degree fitting with a hose barb on one end (top) and NPT threaded bottom end. Then I can thread on a lenth of 3/8" flared line to put the return...
Wow! That’s some serious finagling! The sending unit looked the same size as the gas door opening; I did NOT think that was possible.
If you run into any problems hacking up your sending unit and totally screw it up somehow just let me know and you can have my old one for free and try again. (I’m obviously not using it anymore.)
Adam
Old Sep 7, 2018 | 10:40 AM
  #44
mobird's Avatar
mobird
Adam
Yeah I thought the same, looked like there was no way, but I figured it was worth a shot! Actually pretty easy, just have to angle it a little and rotate it. Only took me like 30 seconds once the hoses and electrical connections were off.
Thanks man! Hopefully won't be an issue, seems like a pretty straightforward job, but I appreciate it!
Old Sep 7, 2018 | 01:15 PM
  #45
lionelhutz's Avatar
lionelhutz
I know what you mean, people love their AN fittings for almost anything custom. A 90* AN-AN bulkhead fitting with a straight hose barb fittings on top?
Where are you finding a nut that fits the NPT thread, or are you making one with a tap?
Old Sep 7, 2018 | 02:42 PM
  #46
mobird's Avatar
mobird
I thought about that, but then I still need a AN-Hardline fitting underneath since I want to run the return line below the fuel level to minimize the air bubbles in the fuel, as recommended by most EFI manufacturers. So totally doable, but would end up costing like $50 at the cheapest with all the fittings, plus I would have to order them and I'd like to get this part done and get the sending unit back in tonight.
Still kinda brain storming that part, right now I have a 90 degree fitting with a threaded end and a 3/8" hose barb end. I figure I will tap the top of the sending unit for the NPT thread and screw it down, then screw on an adapter that has 3/8 hardline compression on one end and NPT threads on the other to the underside of the sending unit. Liberally JB weld both sides to make sure it is leak-proof and I should be good. Then just attach a section of 3/8 hardline to the compression fitting.
