68 center interior bezel
Old Sep 7, 2018 | 01:44 PM
harmoe's Avatar
harmoe
Default 68 center interior bezel
It appears that where the screws enter the dash on the side, the screw holes are stripped. The screws won't tighten. Any suggestions?
Old Sep 7, 2018 | 04:47 PM
ronarndt's Avatar
ronarndt
If you are talking about the center console, where the radio and gauges are located, you can build up the area where the screws go with JB Weld or epoxy and then re-drill the holes. Remove the screws, tilt the console to get access, build up substantial reinforced area with the epoxy and then carefully re-drill the holes. Don't over tighten the screws or you will be doing the whole job over again.
