Reverse Light Switch
Old Sep 3, 2018 | 06:47 PM
Mike1973's Avatar
Mike1973
Cruising
Default Reverse Light Switch
Hello All
I am new to the forum and just purchased my first Corvette a 1973 convertible 4 speed. I have had many cars over the years but never a vette, before this one. I am currently sorting out most of the mess made by the PO and noticed the reverse lights were not working and when I removed the center console to fix some other issues I saw that the PO had attached a ridiculous switch to the side of the shifter. I removed the switch and attached the pink and green wires and still no lights. I went under the car and found that there was also a switch in the trans. I need to replace this switch as it is bad. Now for my question. The switch is located in the front left of the trans and it is a screw in single pin switch. When I look up reverse switch for a 73 all I come up with is the switch that attaches to the linkage. Can anyone tell me what switch I need? Did all 73s come with the Linkage type switch? I am wondering if the trans was swapped out somewhere along the cars life.
Thanks for any advice
Old Sep 3, 2018 | 06:54 PM
DUB's Avatar
DUB
It will depend on what transmission oyu ahve.
The reverse light switch actually is connected to two bolts for the side cover adn rod is attached to teh reverse linkage.
The PINK wire should have battery voltage on it with the key ON.
Put 12 volts to the light green wire and see if the reverse light light up. If they don't...then you have other issues that obviously will need to be addressed and I am not going into every possibility of what problem you can have until I hear back from you on this.
DUB.
Old Sep 3, 2018 | 07:06 PM
Mike1973's Avatar
Mike1973
Cruising
DUB.
As I said I do not have the switch connected to the linkage The switch is screwed into the trans. I can get the lights to work but the trans switch is bad. I cannot find a part number for that switch
Old Sep 4, 2018 | 10:38 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
the switch is adjustable, remove from transmission and test switch.
if good reinstall and adjust. ...if bad replace it, it is a very simple switch.
Old Sep 4, 2018 | 11:46 AM
Mike1973's Avatar
Mike1973
Cruising
I know the switch is bad I just cannot find a part number for the switch on any of the parts sites. They only list the linkage type switch for a C3. I am asking if anyone happens to know the part number
Old Sep 4, 2018 | 12:04 PM
Duke94's Avatar
Duke94
I thought they all used the same switch. Do you have a picture of the one you have?
https://www.ecklerscorvette.com/corv...1968-1978.html
Old Sep 4, 2018 | 12:07 PM
redvetracr's Avatar
redvetracr
you are not listening, you are looking at the TCS or TSC (trans controlled spark switch) not the reverse light switch. as posted the backup light switch bracket mounts with two bolts to the side cover and attaches via a little rod to the reverse lever
Old Sep 4, 2018 | 01:20 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Hello All
The single pin switch you're looking at on the transmission is NOT the backup light switch.
It's an emissions switch for the TCS system.
Old Sep 4, 2018 | 02:00 PM
Mike1973's Avatar
Mike1973
Cruising
Thank you that is exactly what I was talking about. Now I know I need to replace the entire linkage switch as none of it is present. thanks for the replies
Old Sep 4, 2018 | 05:55 PM
DUB's Avatar
DUB
And KNOWING what type of manual transmission you have does make a difference when you go to buy this stuff.. It will be MUNCIE or BORG-WARNER. The rods are completely different and also the mounting bracket.
DUB
Old Sep 7, 2018 | 09:08 AM
Mike1973's Avatar
Mike1973
Cruising
DUB
Thank you I did notice that when I looked up the parts. I will be sure to check before ordering the parts
To Reverse Light Switch
