Rear diff gear ratio?
Old Sep 5, 2018 | 12:13 PM
Tommy K 47's Avatar
Tommy K 47
Default Rear diff gear ratio?
Can Anyone tell me what rear diff ratio I have by knowing my RPM at a certain speed? I was told it was the stock 3.08 but not sure. I have a 78 L48 with a th350 and at 3000 rpm I’m going just under 75 mph.
Old Sep 5, 2018 | 12:39 PM
forman's Avatar
forman
What’s your engine suffex... first 3 letters
Old Sep 5, 2018 | 12:40 PM
lars's Avatar
lars
Originally Posted by Tommy K 47
Can Anyone tell me what rear diff ratio I have by knowing my RPM at a certain speed? I was told it was the stock 3.08 but not sure. I have a 78 L48 with a th350 and at 3000 rpm I’m going just under 75 mph.Thanks
You have to know the actual tire diameter. Give me that and I can tell you the gear ratio.
If I make some assumptions and assume you have a 27 inch tire with about 5% converter slip, your rear end ratio is the stock 3.08.
Lars
Old Sep 5, 2018 | 02:48 PM
HeadsU.P.'s Avatar
HeadsU.P.
Those code numbers prove nothing but what was in there 40 yrs ago. Who knows if it has been changed.
Old Sep 5, 2018 | 04:01 PM
Tommy K 47's Avatar
Tommy K 47
thanks Forman but I can’t currently see the number and that wouldn’t help me anyways because I already know it came stock with a 3.08. I’m wondering if the previous owner might have changed the ratio and I’m not currently able to turn the tire/wheel one complete revolution while counting how many times the driveshaft turns or I could figure it out that way.
Old Sep 5, 2018 | 04:26 PM
Tommy K 47's Avatar
Tommy K 47
Lars
Thank you Lars, yes they are the original p255/r60 15’s and I believe they were 27”. I’ll have to look them up to be sure. They’re the Firehawk Indy 500 brand.
I thought maybe the rpm seemed a little high for that speed but I guess not. I’ve read posts where guys have run the 700r4 with a 3.73 and with the 1:1 3rd gear they were at 3500 rpm at 70 mph and with the overdrive it dropped to 1900 rpm at that speed? I know the overdrive really helps but I didn’t know to what extent. Does that sound right to you? Thanks Lars 😊
Old Sep 5, 2018 | 04:48 PM
lars's Avatar
lars
I thought maybe the rpm seemed a little high for that speed but I guess not. I’ve read posts where guys have run the 700r4 with a 3.73 and with the 1:1 3rd gear they were at 3500 rpm at 70 mph and with the overdrive it dropped to 1900 rpm at that speed? I know the overdrive really helps but I didn’t know to what extent. Does that sound right to you? Thanks Lars ��
The 255/60R15 tires are 27" as I assumed, so based on the numbers you provided you have a 3.08 rear end - no doubt about it.
Keep in mind that the 700R4 has a lockup converter, so there is no converter slip - you can't compare that tranny to your TH350. You have about 5% converter slip which raises your rpm at any given speed. Yes, a 700R4 in overdrive with the converter locked will run under 2000 rpm at over 70 mph: I had an '85 C4 with that tranny, and that's what it ran.
Lars
Old Sep 5, 2018 | 04:59 PM
Tommy K 47's Avatar
Tommy K 47
Lars
thanks for the info!
To Rear diff gear ratio?
