1976 Tilt/Tele Column Question
Old Sep 9, 2018 | 12:57 PM
Donny72's Avatar
Donny72
Default 1976 Tilt/Tele Column Question
I am having brain fade here! Is a 1976 tilt/tele column the same as a 70-75 other than the wheel and the tele mechanism? Can I put a pre '76 hub and top parts to put it on my '72 is what I can't remember.
Thanks!
Old Sep 9, 2018 | 06:23 PM
DUB's Avatar
DUB
I believe so.
DUB
Old Sep 9, 2018 | 06:51 PM
'75's Avatar
'75
Willcox used to sell a kit to swap from the 4 spoke to the normal 3 spoke. It had the hub, shroud and horn parts.
Old Sep 9, 2018 | 06:55 PM
'75's Avatar
'75
https://willcoxcorvette.com/corvette...version-kit-76
Old Sep 9, 2018 | 11:38 PM
naramlee's Avatar
naramlee
I havn't had mine apart yet, but 76 is a special year, the spline hub is built into the wheel IIRC... I will have to pull it apart soon though as I didn't read directions when I did my Borgeson swap I ended up with it 90* off where I need it
Old Sep 9, 2018 | 11:48 PM
bfit's Avatar
bfit
I think the differences are mostly exterior, like the horn assembly
The main parts that wear are interchangeable .
Bfit
To 1976 Tilt/Tele Column Question
