in re installing my 68 brake light switch, I can't get the switch adjusted so the brake lights are off.
is there a trick or procedure to adjust the switch on the pedal housing so it is forward far enough to turn the lights off when the pedal is not pressed.
it's an original switch that works, and the pedals and housings are original but this car has been taken apart and restored, I'm just trying sort out the electrical and wiring.
trying to adjust this under the dash is a real PITA....
I accidently bought a Brake Light Switch that also had the clutch neutral safety switch incorporated. Because I have an automatic, I did not use the other two prongs for the clutch wire harness. You are not using the wrong prongs are you?
You may have to keep playing with that adjustment nut to get it just right. It helps to do this in a dark garage with the door closed. You will be able to monitor the brake lights reflection.
