Rocker panel screw hole question
Old Oct 11, 2018 | 06:38 PM
Ramirez1976's Avatar
Ramirez1976
Default Rocker panel screw hole question
So finally got the correct screws for the rocker panels and was just wondering if this:
Metal insert.
Wondering if that metal piece is supposed to be there or if it is supposed to be empty like the rest of the holes.
Can't get the screw in with that so I'll just skip over that hole for now. Let me know what purpose that serves. Thank you.
-Ben
Old Oct 11, 2018 | 07:37 PM
forman's Avatar
forman
they pop in from the back ,,, the t inserts
Old Oct 11, 2018 | 07:39 PM
forman's Avatar
forman
lowes has them
Old Oct 11, 2018 | 08:27 PM
Ramirez1976
Originally Posted by forman
lowes has them
thank you! Ill be buying some soon.
Old Oct 11, 2018 | 11:36 PM
7T1vette's Avatar
7T1vette
As I recall, those are #10-24 threaded inserts; and T-nuts (as mentioned above) will substitute for them. Several of mine were rusted to oblivion, so I removed what was left of them, cleaned the surface off well, and inserted some stainless steel T-nuts with a bit of epoxy on the mating surface. After curing overnight, the rocker cover installed easily and well.
Old Oct 12, 2018 | 04:17 AM
NONN37's Avatar
NONN37
I took/drilled off mine and the inserts were only in the 3(or 4) middle holes. the ones toward the front and the rear wheels had regular nuts. only the middle ones had the inserts because its hard to get a wrench between the frame/body.
Old Oct 12, 2018 | 08:29 AM
Cavu2u's Avatar
Cavu2u
I found the thread size of those guys on my '73 as 8-32. But some were so damaged, I found a 10-32 tap restored those.
Steve
To Rocker panel screw hole question
