On my 82 it only shows half a tank on my guage when it has a full tank. As I drive and use gas, once it gets to half a tank the guage seems to work from there. Any suggestions would be greatly appreciated.
thanks
Most likely the gas gauge float is hanging up on something in the tank. The manual will tell you how to pull the fuel pump assembly out and that will allow you to check the gauge float.
Typically the liner in the tank goes bad and when this happens gas gets behind the liner and pushes it outward. When this happens the float will come in contact the liner and only go up as far as it can.
You can remove the sender from the car, there are tons of info on how to do this on this forum... then check the condition of the liner inside the tank and evaluate your situation.
The problem is NOT the resistor, it's somewhere else....
A gauge with a blown resistor will only read slightly past 1/4 tank of fuel... and while the gauge will still operate it will only operate between slightly past 1/4 to empty. Since you said the gauge was reading 1/2 a tank this takes the resistor out of the equation. (see the picture below)
While some of the stuff on the site has pictures that state 1968-1976, the gauges all work the same from 1968-1982.... so the testing is the same.
So.. see the pictures below.
To bench test the gauge, apply power to the 3 oclock stud, then apply ground to the 6 o'clock stud.... the gauge should to to full as pictured below, next you'd want to ground out the ohms (9 o'clock) stud to the ground stud and the gauge will go to empty. If this works then there is nothing wrong with the dash unit... if this fails then you have a gauge issue but it's not the resistor.... Like I said above, a gauge with a bad resistor will only read slightly above 1/4 tank...
