Header wrap - opinions
hi jim,
looks like you did a great job! We appreciate the support and are more than willing to bet you will be happy with the lower temps. Feel free to contact me on any exhaust wrap myths or urban legends as i will be more than happy to dispel them. Also, if there is anything i can do to help out down the line simply reach out to me. timm@designengineering.com
thanks again,
tim
thanks again,
tim
Wrap does work for lowering temps. but does cause pipe damage, if you run it enough the damage wont be rust as stated above,
The damage is from the steel pipes getting super hot under the wrap and the inside layers of the steel will turn red and peel off like an orange.
After a while, maybe a year or two the headers will get real thin,from the inside out, and will crumble. A turbo wraped up will not do this because most of them are made from Cast Iron and will last a long time.
Former Vendor
Hello All,
I'll briefly touch on this as many have their own opinions and thoughts on the subject of wrapping headers. We've been in business for over 20 years manufacturing and selling exhaust wraps. There are many different "recipes" of engines, header manufactures, coatings, installations, and other factors that can play into this subject. In general most wrapped headers with a high temp header paint or silicone spray will last many years and provide many years of service. Metal fatigue can occur if header/pipes are double/triple wrapped or have a thicker ceramic coating on them and then wrapped over. Which is typically why we only recommend 1 layer of wrap with a 1/4" overlap. Also, wraps are a woven material so they still allow headers/pipes to "breathe" and do completely encase pipes. Again, most of the time even a wrapped pipe with a ceramic coating you will still see a long service life. Let's not forget either that headers themselves do not last forever and also have a service life and different manufacturers use different types of metals and wall thicknesses. As for pipes degrading from the inside out, things like condensation sitting in pipes, a thicker ceramic coating, living by salt water, or just a vehicle sitting can also attribute to this happening. Take this information how you want. I just wanted to point out some factors that get over looked and in many cases the exhaust wrap is blamed for some of these things happening. Please feel free to contact me if anyone has any questions.
Happy Halloween,
Tim
Happy Halloween,
Tim
Tim, I have a question.....
DEI offers a variety of self adhesive heat barriers/reflective materials. If someone were line the exterior of their floorboards (under body) which of your products would work best? Are they best suited for 'track only' applications or do they hold up well (stay stuck) when used for daily drivers?
http://designengineering.com/product...ive-materials/
(I've wrapped under body wires with Cool Tape)
Former Vendor
Check out our Floor and Tunnel II material. It is a 3/16" thick dimpled aluminum facing with glass mat backing, and uses an aggressive pressure sensitive adhesive. It will fold, bend, and hold shape. It also cuts pretty easily with tin snips or a heavy duty pair of scissor. This material is designed to be used on the under side of vehicles. We have had it on everything from motorcycles to trophy trucks with great results. http://designengineering.com/floor-t...e-heat-shield/ . Please let me know if you have any other questions.
Thank you,
Tim
On the street, ever header I have ever seen wrapped, got thrown away after it was unwrapped, due to corrosion.
On the street you get water, = big sponge wrapped around metal pipes. = corrosion !
carriljc (02-08-2019)
Former Vendor
Hi 69Vett,
Please see my post from earlier in the thread about different pipes an conditions.
Yes, water on the street does happen. However typically headers are usually running hot enough to burn or steam off any moisture, no different than an un-wrapped pipe. Hence, part of the reason for wrapping pipes, heat.
If you any questions or if I can help with anything please feel free to contact me.
Thank you, Tim
Thank you, Tim
This is so intuitively obvious to even the casual thinker.
Have you ever touched the exhaust accidentally just before the muffler after driving the car. If this is not hot enough to dry wrap this far back, I don't know what to say.
I also try not to drive in the rain - not because its a Vette, but because wipers want to chatter and washer pump not working.
DEITIM (11-02-2018)
Received 3,139 Likes
I put a layer of the Floor and Tunnel II above the exhaust pipes and along the tunnel where the factory insulation wasn't a year or two ago and it works very well, installed easy and 2 seasons later it's still firmly in place.
I also had the section of pipe from the firewall back to the floor kickup wrapped in the lava whatever (don't recall the brand, may have been DEI) and it made a difference in the heat as well. Aluminized pipe and when I removed it to take the transmission out two years ago there was no indication of corrosion on the pipe and different than anywhere else. That said I don't drive in the rain if at all possible and the pipe in those areas don't have any collectors or pockets to trap moisture...
M
DEITIM (11-02-2018)
Received 1,308 Likes
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
Tim, I sent an email to you about some wrap I need for the exhaust pipe that travels under a fiberglass monoleaf rear spring.
I have to shield the fiberglass spring from the heat of the exhaust pipe. Would the Floor and Tunnel ll barrier be better for this application? Thank you
while it does work well for heat reduction.....it's butt ugly and doesn't last forever for starters. It can hold in too much heat and shorten life of the pipes.
I use it on parts of my turbo setup...but not the headers themselves.
I'd suggest getting a good coating on headers on the inside as well as the outside. It will cut down a lot of heat.
Jim
Jim
cor66vette (02-09-2019)
#33
Well I went ahead and wrapped them with the DEI stuff and wow is that stuff cool! Looks like gold! I used one 100 foot roll and most of a 50 foot roll. I only went as far as before the pipes exit the side of the car. Lots of conflicting info on this stuff but it seems like it would only help keep temps down. I did paint the headers before I wrapped them so they have a good couple of coats of header paint on them. This was before I was going to wrap them. As always, wrapping pipes is a pain in the butt. Lots of feeding the fabric around the pipes and then when you get to the end, hopefully you don't cut it too short (like I did) or too long and waste it. On the passenger side, I ended up grouping all three middle pipes for a short section because they are so close together. They definitely look cool! (not hot lol)
I also used almost three packs of the Summit clamps and bought the DEI clamp tool.
