LS3 Thermostat Degree Question
Old Oct 27, 2018 | 06:11 PM
1rad55's Avatar
1rad55
Default LS3 Thermostat Degree Question
I'm building a 69 Coupe restomod with LS3 engine and was wondering what degree temperature thermostat I should run. I would like to run a 160 or 180 degree thermostat. Is there any issues with computer by running these cooler thermostats than factory? Please advise and thanks in advance for input to my question!
Old Oct 28, 2018 | 12:54 PM
ignatz's Avatar
ignatz
I would suggest you look at the GM Performance website. The LS motors should have a list of all the parts that come with each motor.
Old Oct 28, 2018 | 03:53 PM
7T1vette's Avatar
7T1vette
If you are using the computer, I think you will have to install a 195*F stat. The computer won't go into closed-loop mode until a required temperature is reached.
If you have some concerns about operating temps for the engine, just use full synthetic oil. It is much more tolerant of engine heat; and the engine itself couldn't care less that it is 15*F warmer.
Old Oct 28, 2018 | 04:19 PM
corvettedave383's Avatar
corvettedave383
should be using full synthetic oil full stop with that engine, no matter what
Old Oct 29, 2018 | 10:11 AM
7T1vette's Avatar
7T1vette
Should be using full synthetic oil no matter what engine you have.... (but only if you want MUCH longer life of the engine).
Old Oct 29, 2018 | 11:02 AM
71 Vert LS1's Avatar
71 Vert LS1
I typically run a 180 degree thermostat in my LS swaps. Tons of debate over on LS1 Tech forums. ECM runs the fan. On at 205 and off at 195 degrees. The exception is my Jeep Wrangler LS1 swap. I use it to plow snow in the winter. To get a little more heat in the cab I run a 197 degree thermostat. I'd have to check with my tuner but I think the ECM can be modified to go into closed loop at different temps.
Old Oct 29, 2018 | 12:58 PM
lionelhutz's Avatar
lionelhutz
I would put a 180* thermostat in it.
Any GM EFI from the 90's up that I have looked at went into closed loop WELL before 160*F. All the cold start fuel enrichment stuff is long done by that temperature. This is NOT a problem with the GM systems like it's so often made out to be. A 160* thermostat will not make a GM engine run rich and in open loop.
Old Oct 29, 2018 | 02:29 PM
corvettedave383
thats just silly, what reason would you have to not use fully syn oil? apart from cost and really cost is very small
Iam using a 180 degree with no issues, but iam running different ecu
Old Oct 30, 2018 | 07:32 AM
squared's Avatar
squared
I personally wouldn't use that low of a thermostat, and without some tuning software like HPTuners, would stick with what the OEM used. I put a 5.3 in my boat, (with closed loop cooling) and after it was all said and done with mapping fuel tables, wide band O2, spark, etc. etc. would have been better off just keeping the factory settings and adjusting fuel enrichment to start at 50% throttle. While I'm not an expert in the algorithms on the newer chevy engine management systems, engine temp has to play a big part in it and without full knowledge of what that is prefer to stick with what the stock settings were. Modified engines are a different story.
If there's a cooling issue, it's best to solve it from a system point of view vice trying to manage it with a thermostat. I swapped a V8 into a Vega 40 years ago and cooling was an issue. Never ran quite right, and it dawned on me several years later that the top of the radiator was below the thermostat housing (with no expansion tank), and that was probably the source of my cooling problem, as it was never full and "burped".
Old Oct 30, 2018 | 10:54 AM
71 Vert LS1
Nice thing about the newer LS motors the thermostat is kind of like old small blocks not part of the thermostat housing like the earlier LS1's so they are much cheaper. So changing to different temps is cheap. The LS1 thermostats are $50 each.
Old Oct 30, 2018 | 12:23 PM
ddawson's Avatar
ddawson
I've always used a 180. Closed loop is around 140F. Of course the fans should be reprogrammed.
To LS3 Thermostat Degree Question
