Gearing Toss Up
I hope I'm not going against general rules on the forum as it is my first time posting.
So if I am, just give me a nudge in the right direction and I'll be off.
Anyways, I've got a decision on my hands and was wondering if any of you cool fellas have any insight on it.
I've got a 68' 3 speed with a 2.73 rear ratio.
I'm doing a manual transmission conversion with a TKO 500 (3.27 1.97 1.34 1.00 0.68)
I've also got another 68' Rear with a 3.73 Ratio.
Not sure which Rear would go better with the TKO.
I heard recently that someone had a rear ratio similar to the 3.73 and almost never used 1st gear because it was so short.
In contrast, it would also be rough if the gears were too tall with the 2.73.
Therein lies the rub.
Anyone have any experience or thoughts on the two choices?
You will not like 5th gear with a .68 O/D and 2.73's. 65 MPH would be about 1500 RPM...and unless you have a REAL torquey low RPM combo tuned to perfection..it's going to be a slug.
First gear will be a total of 12.19. A 4.88 and a wide ratio Muncie equal 12.29. So...for drag racing that's a great gear combo. Also real handy with a low RPM engine to get it going easily. It's going to feel real short geared in first.....5000 RPM is only about 33 MPH......but you just short shift into 2nd and away you go. It will FEEL strong as heck!
A much better combo would be a 3.36 or 3.08's. That would get you about 70 MPH at 2000 RPM...but still only about 36 MPH at 5000 RPM in 1st.
If we drop to a 3.08...we get 76 MPH at 2000 RPM and a 10.10 overall first gear.. just a little less than a 4.10 and a wide ratio Muncie would be and better than a close ratio.
If you haven't bought trans yet...you might re-look at the various ratios available. Might be able to get a .80 O/D ratio that gives you a little better combo for the lower numerically gears. The 2.73's with the 3.28 first would be pretty nice to drive. In between a set of 3.73's with a either a wide or close ratio Muncie.
This trans combo is very similar to a late 80's Mustang 5.0. They had a 3.35 1st gear and a .68 O/D. I have one and have had 2.73's, 3.08's and 3.55's in it. The 3.08's were a huge improvement and the 3.55's are even better overall. That's a LOW rpm engine that is happy at below 5500 RPM and makes good TQ for its size.
You didn't describe motor combo but I'm guessing a mild 327?
JIM
Without question go with the 3.73 gear. Personally I don’t mind low rpm over drives. My c5 cruises around 1200rpm at 60mph.
(first gear ratio) x (rear end ratio) = close to 10:1 for a good overall launch and stretch off the line and then the same for the high gear. Look around online and you will get rpm calculators that will tell you speed and rpm for a specific gear. dont go below 9:1 in first or you will be riding your clutch of the line with daily driving and it sucks, I know. Math for the 3.73 x 2.87 = 10.7:1 Thats good stuff
I would say 95% of the diff's I built for OT cars used 373 as the ratio of choice. Some 411 and some 355 but most were 373.
I had to check and yes 273 were an option for BB automatics. I wonder how many were actually built?
http://corvettec3.ca/axle.htm
Now I have a 3.73 diff and love it. 4th is good down to 35 mph and up to 50+. 1st feels perfect, I don't feel like I'm short shifting at all. 5th is good at about 55 and up.
JIM
Trans with the ratios I told about above are locked in and are on their way already.
I've got a 350 in her with some top end work incoming to come to about 340 hp.
Not sure if that changes your opinion on 3.55 being a better overall ratio.
So my tko 500 with the 3.27 first gear and .68 OD are locked in.
So the first gears would be 3.73 x 3.27 = 12.2:1 or 2.73 x 3.27 = 8.9:1
With neither of those being close to the 10.7:1 you calc'd. So maybe it is better to gun for a 3.36 x 3.27 = 11.0:1
Thoughts?
Good to hear that ya nailed your gearing!
I'm starting to think it is going to be a trail and error just like your 3.08 to 3.73.
Maybe it is just something I won't know till shes out on the road and I can get a feel for it.
Not sure if it changes your thoughts on my ratios choices if I have a 350 in her at 340 hp +/-.
Did you ever consider a more middle of the road ratio like the 3.36 or the 3.55?
Cheers
That .68 O/D is made for steep rear gears and/or an engine that is happy to lug down on the highway at 1500 or less. That's why I was mentioning the .80 range as being a little better with the highway gears.
My car has a 3.07 rear gear.....and my 5 speed is non O/D. My first gear is a 3.49 for a total of 10.71. I would like a little more but that's as far as I can go in my trans. On the highway I can cruise with the 3.07's fine...but I would love to have a small O/D to knock it down a little. Oh yeah.....I've also got 1350 HP to help pull it along! LOL
I ran a Doug Nash/Richmond 5 speed for years in my car. Also Non- O/D. I used 3.36's most of the time with a 3.27 first gear and it did very well with my 427. Just made it a heck of a fun car overall...but a slight O/D would have been nice on the highway.
JIM
Cheers
The other time you would really appreciate the 3.36 gears is on road trips with cars getting single digit mileage. After my experience I don't think I would go much higher like the 3.73 on any Corvette I own, I like my sanity. Try a few hours in a side-pipe equipped Convertible with a big block and 4.11 gears and see how you feel. I have done that once, never again!
I am just here trying to learn all I can to be able to get the specs right for when I make the swap to a five or six speed. The wonderful people at Comp Camps told me that the 3.36 rear would be a major limiting factor in the cam selection, they said I needed a higher rear end, at least a 3.73 is what they told me.
I want to know how to select the best gearing combination for the next transmission I buy. I have a (500 hp+) BB and it allows me to go 25 mph in fourth without bucking or any ill actions, the car will accelerate a bit faster in other gears but I love the torque and power.
Recently we bought our daughter a new Camaro with the six cylinder and six speed combination, at first it felt like "two gears too many". After driving it for a couple weeks I really learned to "like" those extra gears, GM designed this car with four speeds for around town and the extra gears get the mileage up to 30 mpg in a Camaro on the highway. Using it as a four speed around town was great and then on the highway I slipped it into 5th and 6th and was very pleased. I could get used to having five or six gears really easy if set up like that transmission is. GM seems to know what they are doing on that Camaro, it is a nice car.
Who makes a good transmission that can handle the power without breaking the bank? Is there anything different about the gearing when using a BB?
Thanks for sharing all this with us, I have learned a good deal from this forum! Thanks to all of you!
