Lites up upon starting
Old Nov 4, 2018 | 04:11 PM
Cigars4me's Avatar
Cigars4me
Default Lites up upon starting
1972 BB, just rebuilt entire headlite vacuum system. Now, as soon as engine starts, buckets pop up and stay up after engine turned off. Any ideas?
Old Nov 4, 2018 | 06:30 PM
kansas123's Avatar
kansas123
I guess you have double checked all your connections more than once. Absence of vacuum to the lighting system would cause that or having a couple of vacuum hoses hooked up backwards. Is the override not pushed in/up? Did you do anything with the switch mounted at the back of the tach? How do you get the lights to 'go down' now?
Old Nov 4, 2018 | 07:06 PM
Cigars4me's Avatar
Cigars4me
Override pushed up. I lower buckets manually from below the lights. I’m going to change check valve next.
Old Nov 5, 2018 | 06:23 AM
derekderek's Avatar
derekderek
Vacuum moves the lights in both directions. It's not vacuum one way and spring the other. So it's something to do with the vacuum switching.
Old Nov 5, 2018 | 06:25 PM
DUB's Avatar
DUB
Agreed. The small vacuum hose that goes to the small port on your actuator relays MUST have vacuum on it in order to keep the headlight doors down. When the vacuum is stopped to this hose...then the headlight doors go up.
Assuming you have the hoses from the actuator to the relays are correctly routed.
DUB
To Lites up upon starting
