Hi,
Does anyone have information regarding the position of the air doors inside the heater box? I want to know what position the doors should be in based on the mode selected on the thumb wheel. It is original system using R12 refrigerant.
Over the last year the AC has lost efficiency. The air conditioning is serviced properly and has correct operating pressures. With outside temperatures of 80 degrees or less, the system cools well. Above that it does not cool so well, with duct temp of about 55 degrees. It seems as if one of the doors is blending outside air with the conditioned air even in the max cool position.
Courtesy of Willcox, a forum supporting vendor, here is a link to the heater/AC operation schematic for a 1974; a 73 operates in a similar fashion. http://repairs.willcoxcorvette.com/w...-schematic.pdf
The doors may be operating properly but not closing/opening all the way due to deteriorated seals or a rodent may have left something in there.
Other 73 owners that have worked on their heater boxes (Cavutu Steve comes to mind) recently will hopefully chime in.
Fran
Reason: rewording
I can see the door with the orange hose open when I select max air. I cannot see the door with the green hose, how do I access that area?
Go to the chart where the valve has the colored circles... choose that port and then test it with a migy vac.... I believe this to be port 1 but you'll know because the hose will have a stripe that color on it. Then test this to see if the vacuum pod is working. To see if this function is working.. this is the fresh air vent blocking flap located under the top of the passenger side inner fender. So you'll have to test it to see if the vacuum pod is pulling the door closed.... you can also simulate this to the vacuum chart listed at the bottom of the picture I posted... It's not that hard and be thankful the issue isn't the a/c door behind the center cluster..
Willcox
If you get a chance, please bump or Black Friday Sale threads on C3
That is your COWL AREA fresh air door UNDER the right side top hood surround panel. Raise your hood and stand on the DRIVERS SIDE of the car and look at your PASSENGER SIDE wiper arm and UNDER the top hood surround panel you will see the flapper door. The actual POD is BEHIND it like in the drawing.
And YES...this hose can come off and get plugged up. The thread below is a 1969 but it in the same area.
I'm not sure why you TTT'd this post, if you use the chart in the lower left you can see it tells you which pod has vacuum on it and in what position, it also shows you the diverter door and what position it's in in what stage? Did I miss something?
If so post back. On the down side, to do this testing you'll have to remove the heater control from the car so you can watch the vacuum select switch to see what position it's in. I've got a write up on my tech site that will help you remove the heater control if you need more info. You've got both mine and Dubs ear so post back.
Willcox
Got back to it yesterday. All of the doors are moving correctly per the diagram Wilcox graciously provided.
I am thinking perhaps the VIR valve has an issue. So that raises several questions:
1) Is there a way to confirm VIR is failing in warmer outside temperatures?
2) If it is the VIR, do I go with a replacement VIR or install a VIR eliminator kit? Still running R12 and have plenty on hand.
I am by no means an A/C tech by trade. I know enough to be dangerous. So being able to tell you WHY it will or will not work under certain conditions is not in my wheelhouse of knowledge.
But I have replaced many VIR's and went with the VIR eliminator kit with great success on those Corvettes where the owner did not care if the car still looked original.
My A/C guy uses the 134a Freon adn R-12. It all depends on factors of potential leaking where the cost of R-12 is much higher than the 134a....but I know you can more than likely use the R-12.
In the thread linked to you below. On Jims system on his 1974 when I installed the VIR eliminator kit this is what happened and thankfully it was charged up with 134a Freon. I corrected this problem and now this O-ring does not nor CANNOT ever come out. Look at the photo in POST#10
Jim can tell you that his A/C system runs so cold...from his own words...he an sell ice cream out of his car on a hot summer day. Granted all new parts were installed for the condenser to evap core and a compressor rebuilt by Dominic and new hoses. And yes his car also has the twin SPAL electric fans also.
