Engine blew up! Help analysing possible causes
You'd be surprised how well you can tell what happened when looking at the damage.
And today he also managed to pull the engine on his own
The first results are:
- all valves are still in place,
- Two pushrods visibly bent,
- Valvesprings seem to be in order,
- Head- and intakegaskets were not blown,
- Cilinder 5 and 6 MIA,
- Pistonrods still attached to crank,
- Other pistons and rods seem ok, not cleaned up yet,
- Flywheel looked pristine,
- Oil dipstick not so much
Photos will follow tomorrow. Will send cam, crank and heads out for inspection this week.
I will check that today.
Cam bent?
I can't remove the camshaft: it binds as I move it to the next opening (tech. term?). Turning or moving side to side does not help.
As far as my carpenters eye can see it is bent. How to verify this? Or is the fact I'm unable to remove it h enough evidence?
(Cries a little over losing his XE274H nitrated can).
Salvageable parts
Think all pistons are scrap since most have either scuffed or scarred top surfaces or the skirt is damaged.
Some rods seem undamaged; wise to reuse them?
Crankshaft seemed to be ok; will bring it to a shop tomorrow.
Cam bent?
Salvageable parts
question is why the piston hit the plug and an open valve?
i guess debri from say number 5 cyl could have been sucked into 6
and broke that plug?
or,,,,, 5/6 crank journal twisted and put the piston where it should not have been
It's the weakest link in all the parts you mentioned. And is a common failure point in an engine that gets "pushed hard". Seen it a hundred times in my buddy's engine shop.
Everything else is collateral damage. It's just not that wise to use those pistons in a engine that gets run hard often. They're more of a street performance piston that only occassionally gets run hard. How hard is too hard and how often is too much????? It's expensive to find out. Jeff hates these pistons, thinks they are way over-marketed and over-sold.
As others recommended, definately go with forged pistons on the new engine. And not too much compression, 9.5-10.0. You had ARP rod bolts, do that again. Then just keep it under 6000 and you should be fine. Switch the crank from cast to forged if you want to go past 6000 regularly, and still live a while. With all the good factory forged stuff you can rev it higher, and live. My 70 LT1 ran great for 29 years, and 25,000 miles, and many 7000+ rpm blasts autocrossing, and the only "extra" was ARP rod bolts. Never apart once.
Good luck
You can now decide i guess depending on money at hand what direction you are going to go? A GOOD WELL BUILT engine is not cheap, Period.
Good luck
I mentioned the same back in post #85 and it is well known that Hyper pistons CAN be a weak link. The response from some was hypers are used by GM on The LS7 stock and so and so used hypers in their build revving it to infinity, and had no issues..................Give me a break!
My builder who is an EXPERT said the same as your builder about hyper pistons and their potential weaknesses...hmmmmmmm
DUB
Mike
While there's no labelled expiration date on our car parts, they do Not have an unlimited Life expectancy. No matter if it's a $5 main bearing shell or a $10 piston or a $100 piston or even a $1000 piston; they all have a Life Cycle. An inherent limit to Life itself. Hence Engineering's MTTF, MTBF etc.
Again, I do Not KNOW what caused OP's engine failure or piston failure.
Also, I do Not KNOW what caused MY OWN engine failure or piston failure from several years back. I had a 355" local rules asphalt circletracker with light CP brand pistons forged of 2618 aluminum alloy. At full-song, engine blew up mid-race without warning. It did Not drop a valve Nor break a spring. Except for 2 or 3 rods, everything was destroyed including a windowed block. It SEEMED as though a piston was a fault: snatched it apart just between oil ring land and pin boss. Maybe a shell was failing and allowed the piston to rock and then a ring snagged in bore and snatched MY pin boss away? Maybe MY bores' finish hone was bad? Maybe this or that or dozens of other maybes. But I don't KNOW. My best (and others too) GUESS is the piston failed first. I've built a lot of motors (using pistons from cast to forged) but the above is the only one I built which snatched a pin boss apart.
Do I blame that parted piston? Heck NO, I do Not! CP has a very good reputation. But this kind of failure can and does happen to even the cream of the crop. My pricey pistons had a lot of time on them; Many Many Life Cycles. Those are some rather expensive pieces and I chose to use what I had. Before freshening this motor, they were carefully inspected using gages and eyeballs. I think MY pistons had reached the end of their Life Cycle. I'd gotten the goody out of 'em; got my money's worth. They might be part of that frying pan I got last year.
Not MY CP pistons' fault; they simply cycled out.
Is 2618 more resistant to breakage than most other piston alloys? Sure it is! But stuff still breaks.
plugs and open valves?
both on 1 crank journal.
odds or that happening must be really low.
1 bad piston, ok. 2 leads me to think that some
install procedure wasn't right.
damn shame
