Engine blew up! Help analysing possible causes
If you throw a similar roller cam in a gen 1 or a gen 3 with the same intake and equal heads you will get similar HP. These motors are just an air pump and all things the same, It will produce the same. You guys are getting off of the main topic, how about you leave this thread to the OP and you guys go argue your issues out in a new thread. Thanks for coming, theres the door
https://en.m.wikipedia.org/wiki/Chev...l-block_engine
Like I said, The issue with Hypers is they do NOT tolerate detonation well of any sort like a forged piston..No detonation issues and I would predict that Hypers are fine......
Yes I have heard the same about the 383 inherently not being an optimal design. Maybe why GM never produced a 383 V8 engine, much less ever for a vette???? Anecdotally, there seems to be more than a fair share of 383 blow ups....any engine experts know if the 383 has less tolerance for improper engine builds versus a more forgiving tried and true 355 V8?
Yes my LS7 absolutely does use hyper pistons from GM in my Z06. I have heard though the issue with hypers from my expert builder who did my L-82 355 bottom end only that the hyper themselves are fine BUT they will NOT tolerate any detonation which helps explains there use in the 427 LS7 since modern ECU computer engine management severely limits any piston detonation....Hypers are NOT a great choice for a Gen1 High Gross HP V8 since there is not adequate anti knock technology on most of these motors......for the uninformed
If you're not going to go with a forced induction engine that makes 4 digits worth of horsepower, the 4032 alloy is the way to go. Mahle has lots of 4032 pistons for the smallblock, as does JE in their SRP Professional line of pistons.
I would assume my LS7 in the Z06 then is the 4032 piston?
Not sure what the JE Forged Racing piston is in my L-82 355..it has zero piston noise/slap even when stone cold....4032 as well?
I would assume that possibly you lost a piston due to maybe detonation or the rod angle. 383 do not like high rpms. piston broke and the resulting carnage.
I know a lot of others have had good luck with the same combo but others haven't..... Its a combination I really don't like, like I said. I would tend to lean towards a 377 but just my preference.
Hopefully we can all get back on track to the op.
Flame away.
As far as the pistons in your L-82, if they're branded as JE pistons, they're probably 2618 alloy. If they're branded as SRP or SRP Professional, they're most likely 4032 alloy.
Thanks for the great info that is useful for most.
As far as the OP goes, not sure there is much more to be said at the moment until he determines the origin of his failure and decides what he wants to do now based on everything suggested so far concerning all his options......................
Seems the debate here is on semantics. Does small block refer specifically to size or to generation of engines which were virtually identical except for the bore.
The real debate comes down to the old saying, there's no replacement for displacement. This is not true. If I said, all else being equal (to the extent theoretically possible), fuel, aspiration, exhaust flow, cam specs, redline, etc. etc., then it is true, you need more displacement to get more hp. But hell, torpedo engines produce several hundred hp on displacements more in line subcompact car engines. So is a torpedo engine a small block and a Pratt and Whitney R4360 28 cylinder 4,363 cid radial a big block? In the "all we're talkin' 'bout is size world", yes. In the automotive terminology world I'd say no - Chevy 396 / big block; Chevy 400 / small block.
Po-tay-to, Po-tah-to
DUB
Well, you ~could~ build a very, very well executed smaller displacement forced induction engine that could do fairly well down low torque wise emulating a bigger displacement engine.
What would make the heads "equal" between a small block and a LS engine? If you picked intake runner cc as the main metric when building a small block to match the power of a LS3 then you'd be using 260cc heads on your small block build. That's a lot of intake runner cc to use on a 383 cu-in 430hp small block build and you likely wouldn't be happy with the result on the street. This is my point. The 2 engine families have enough fundamental design differences that "similar" parts don't just work the same between the two engine families.
As for the rod/stroke ratio. Evaluating rod length based on the rod/stroke ratio it causes is probably the most over-blown part of engine bench racing. The 383 gets way too much attention for having a "poor" rod/stroke ratio. Long stroke big blocks end up with a much worse rod/stroke ratio then a 383 with 5.7" rods yet you don't read much about how those builds are terrible because of it like you do with a 383 small block. It's just accepted to be what it is. You're much better off evaluating rod length based on the piston design (lightest weight yet wrist pin not into the ring pack or compromised strength) and any possible help with clearances it gives you.
4.40 for the ls7 (=same as prior ‘small block’)
4.84 for Big Block 427, 454, etc.In other words, the bore spacing determines the term big block or small block, not the displacement. However, the larger bore spacing allows for larger pistons, hence a larger displacement using similar crank throws.Other manufacturers have similar bore center spec differences
If I go for a replacement build, then I'm saying build it to the quality of the L82 which is a rock solid engine, again - my understanding. Forged steel crank, not cast iron and certainly not nodular; forged rods, forged pistons, and whatever else provides safety margin both against my abuse (intentional or otherwise) and the possibility that some defect does exist and for the fact that sometimes all the allowed manufacturing tolerances happen to go toward the worst case, though still in spec, direction.
Having spoken with a high school buddy of mine who started a racing engine business pretty much straight out school 40 years ago and is still going strong, he offered me two options on a build, both starting with good used 4 bolt main block. Going with nodular crank, cast pistons and rods, off-shore heads, etc. about $3500. Going with parts of like manufacturing quality of the L82, about $5,500. He stated that he did not have any qualms about building the $3,500 engine since the target hp was 400. So he in no way was trying to scare me into the $5,500 build. I just see the the extra as a reasonable price for the extra peace of mind I'll have.
But, as noted, that's based on one professional builders information, my experience beating the crap out of the L82, and, though not previously mentioned, my brother blowing up his '74 Camaro 350 in '77 (sucked a valve on fuelie heads being pushed with a solid lift cam), and some of the insights (incites? maybe both) in this thread (and others). I am though always happy to get additional input given that there are a lot of far more experienced people than me here.
Thanks,
It was recommended and the engine builders I was working with referenced that it was a perfect square with a 4" stroke and 4" bore.
They stated that with that combination they found fewer failures than with 413 or 428 sbf builds.
I was never sure how true it was, but it was a fun motor.
Could the same balance be true for a sbc motor?
