Gas Tank Paint -76
Old Nov 27, 2018 | 10:42 AM
hgoodwiniii's Avatar
hgoodwiniii
Default Gas Tank Paint -76
HI all, what's everyone using to paint/coat outside of gas tank?
Old Nov 27, 2018 | 06:01 PM
teamo's Avatar
teamo
I used Eastwood tank refinishing kt. Comes with rust converter and a can of tank tone which is a zinc rich silver color. Came out pretty good.
Old Nov 27, 2018 | 06:32 PM
DUB's Avatar
DUB
I know the 'weld-thru' primers are super high in zinc and are silver and cover lightening quick...just as an option.
DUB
Old Nov 27, 2018 | 09:24 PM
mortgageguy's Avatar
mortgageguy
I used Seymour 16-055 Alumi Blast. About $11 on Amazon.
Old Nov 28, 2018 | 09:02 AM
squared's Avatar
squared
Crystal Drano on the inside to clean out the old gas/tar etc. Put the water in the tank first, then the Drano..it off-gasses hydrogen so do it outside. OSPHO inside and outside to neutralize the rust...rinse/dry. Brush off the white Phosphor residue with a scotchbrite pad or wheel depending on how much there is. Two part Urethane from an automotive paint store to seal it...can be brushed on if you don't want a shiny finish. Two part urethane topcoat in the color of your choice from the same paint store, again, brush if you're not concerned with the finish quality.
To Gas Tank Paint -76
