Fuel pressure regulator
Old Dec 12, 2018 | 11:13 AM
CaptainMorganUOR's Avatar
CaptainMorganUOR
Default Fuel pressure regulator
I have a 72 with the Edelbrock carb
The fuel pressure regulator was DOA, so I replaced it with the only one I could get my hands on quickly, the Mr Gasket (knowing there are issues). Right away, the pressure was higher than the setting. I had to set it to 2lbs to get around the 4lbs needed. After about a week, it's now basically a straight through and my gauge is topping out.
So, any recommendations for a decent unit?
Old Dec 12, 2018 | 12:14 PM
MelWff's Avatar
MelWff
the minimum pressure is 4 to 5 pounds the recommended pressure is 6.5 pounds so did you measure the pressure without a regulator?
Old Dec 12, 2018 | 12:44 PM
CaptainMorganUOR
I've not pulled it out completely, but it's currently pinging my gauge at the max 15lbs
Old Dec 12, 2018 | 04:10 PM
7T1vette's Avatar
7T1vette
5 psi is more than enough for any carb. Over 7 psi is too much for many of them. Buy a better regulator on the web. It will be at your house in a few days and you can swap the junk one out. (Then take it back to the store for a full refund. All you need is your sales receipt.)
Old Dec 12, 2018 | 08:48 PM
Street Rat's Avatar
Street Rat
I have a bunch of Holley regulators. I use Aeromotive regulators now.
I will send you one for free if you pm me your address and pay the shipping.
Craig
Old Dec 13, 2018 | 07:14 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I've had good luck with Holleys as well
Old Dec 13, 2018 | 11:35 AM
MelWff's Avatar
MelWff
If you have a reading of 15 psi you haven't given us all the information concerning your car, a factory pump does not put out 15 psi. What kind of fuel pump are you using?
Old Dec 13, 2018 | 12:46 PM
CaptainMorganUOR
Stock, so I'd also ordered a new gauge with the guess that could be the issue as well.
Old Dec 13, 2018 | 05:45 PM
MelWff's Avatar
MelWff
It does sound like a gauge problem, please let us know if replacing the gauge gives you normal pressure readings.
Old Dec 22, 2018 | 01:28 PM
CaptainMorganUOR
It was the regulator. The new gauge read 10psi. With the Holley in there, turned down to 5psi everything is humming along nicely.
Thanks all!
Old Dec 27, 2018 | 10:11 AM
Street Rat's Avatar
Street Rat
Thanks all!
I'm glad you found the issue.
To Fuel pressure regulator
