persistent spark plug fouling
Old May 16, 2019 | 09:46 AM
  #101
jim-81's Avatar
jim-81
I was also going to suggest if you have an old carb laying around to pop that on and see if that helps. As far as tuning the carb, I would think that it should be pretty close out of the box for a mild 350. I had the 650 AVS on my 350 for several years and it ran great. I did some tuning with rods/jets but not too much. I also installed it on my new 383 without any adjustment and it ran great. I recently upgraded to a 800 AVS2 on the 383 and it's awesome out of the box. Might be a little rich so my plan it so jet it down a bit.
I also ran into the stumbling block of where to find the tuning/calibration kit and had to have a couple calls to Edelbrock and finally got one. I will post it. At first they sent me the chart for the AVS2 650 (attached PDF). Note that there is no calibration/tuning kit available (which sucks) so you have to purchase all of the rods and jets individually. Using the chart, you have to see what rods and jets you want/need and make a list and buy them. This is what I did for the 800.
For example, using the chart, if you want to go one stage leaner (from base/stock calibration) to number 2, you would need jet 1427 and rod 1449.
Hope this helps. This is fresh in my mind since I have just gone through it.
Jim
Old May 16, 2019 | 08:50 PM
  #102
Japery's Avatar
Japery
Thankyou.Thats what I was looking for. Kind of strange Edelbrock told me that rods wouldnt help a rich condition.
Old May 17, 2019 | 05:50 AM
  #103
Gunfighter13's Avatar
Gunfighter13
Originally Posted by speedreed8
I believe that’s a cold heat range racing plug. Probably need a hotter plug to burn off the deposits for everyday driving.
needs a Autolite 3922
Old May 17, 2019 | 09:08 AM
  #104
Kacyc3's Avatar
Kacyc3
do you have another carb to swap on for a test? Like the 1406 mentioned above? Borrow one not buy, swapping parts like this is a great way to rule out items as bad.
Old Jun 26, 2019 | 09:00 PM
  #105
Japery's Avatar
Japery
To finish up this thread,I ended up getting another edelbrock carb and going one step leaner with the needlesand fixed the problem. Thanks everyone for your help.
Old Jun 27, 2019 | 01:11 PM
  #106
jim-81's Avatar
jim-81
What did you end up getting?
