Header Side Pipes
Old Dec 26, 2018 | 08:11 AM
Red Hot 71's Avatar
Red Hot 71
Default Header Side Pipes
Finally managed to save enough lunch money for header side pipes for my 71 Stingray. Issue now, is do I go w/Doug's chrome set or OBX stainless steel. Both cost roughly the same. Worried about upkeep, longevity, & looks. Car goes to shows frequently with my car club. Thanks in advance for your opinions.
Old Dec 26, 2018 | 09:30 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I would go with stainless steel.
Old Dec 26, 2018 | 12:24 PM
OldCarBum's Avatar
OldCarBum
Polished stainless looks better than chrome any day and it won't rust like chrome.
Upkeep on the stainless is a bit more time consuming though.
Old Dec 26, 2018 | 02:22 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Keep in mind, the tubes will get "sandblasted" by crap thrown up from the tires, so you want the most durable material.
Old Dec 26, 2018 | 02:42 PM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
Default Jet Hot
I went with Jet Hot ceramic coating. Not as shinny but they do run cooler.
Old Dec 26, 2018 | 04:30 PM
3X2's Avatar
3X2
Go for the best: Stahl/ACP
Old Dec 26, 2018 | 04:41 PM
Red Hot 71's Avatar
Red Hot 71
Thanks for the replies. Went w/the stainless steel OBX.
Old Dec 26, 2018 | 07:07 PM
Duane4238's Avatar
Duane4238
Good choice. They are much shinier than the shinny ones.
Duane
Old Dec 26, 2018 | 08:36 PM
BLUE1972's Avatar
BLUE1972
Remember to wear long thick pants, or you will be pealing skin from the pipes.
Old Dec 27, 2018 | 06:51 AM
Red Hot 71's Avatar
Red Hot 71
Thanks again, for responses. How do I post pictures in case I run into install problems? I'm sure it's on this forum somewhere, but not real teck savvy.
Old Dec 27, 2018 | 11:17 AM
MelWff's Avatar
MelWff
below is the link for posting images
https://www.corvetteforum.com/forums...b3_attachments
Old Dec 29, 2018 | 06:42 PM
Stev-o's Avatar
Stev-o
You usually get "kissed" once and then you remember to be careful when getting out!
Old Dec 29, 2018 | 11:01 PM
naramlee's Avatar
naramlee
idk about the other brands, but my Hookers Super Comps you can put your hand on them, granted they are hot, but not 300* for sure
Old Dec 30, 2018 | 12:27 PM
BLUE1972's Avatar
BLUE1972
You need more HP …
It all depends on how you drive - friends 76 with them is ok around town, but after a trip on the highway - you can feel the heat when you open the door.
I have a 67 - factory stock - warm after any trip even highway.
Old Dec 30, 2018 | 03:37 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
1st degree "kiss" - Fak, that's hot!
2nd degree "kiss" - Fak, I may need heat shields.
3rd degree "kiss" - Fak, fak, fak, I'm ordering heat shields now!!!
If significant other experiences any of the above, you may need to choose between the significant other or your vette!!! Buy the heat shields.
Old Jan 1, 2019 | 04:00 AM
Bangkok Dean's Avatar
Bangkok Dean
Shields will assist you with the ladies.
Old Jan 1, 2019 | 02:03 PM
redcruz1120
St. Jude Donor '09
Default 2 Weeks Off From Work!!
..and that was ceramic coating!!..I was out of commission for two weeks!!
To Header Side Pipes
