I have replaced all exterior lights with LED's and also replaced the turn signal flasher relay (behind passenger lower dash pad) with the proper one for LED's. Does anyone have the part no. for the proper emergency flasher relay that mounts directly on the fuse box??
Did you try out the new turn signal flasher to see how well it works for your hazard lights???? I do not have the number right off the top on my head on what would be used.. It has ben a long time since I had exterior LED's going in car.
Thanks Street Rat. I'll give this a try. I'm guessing I will still have to connect the wire to a ground source.??
You CAN use that flasher. The one that you replaced (if the car had one in it) for the turn signals should work fine for the emergency flashers. This was the case on my '81. I used the led type flasher for turn signals and the factory type for the emergency flashers.
If you use the led type flasher the ground wire needs to be attached. I simply used a bolt for the steering column shroud to attach it.
Craig
Tridon 552 should be the regular flasher number
