Cabin Air
Old Dec 30, 2018 | 01:11 PM
psycho dad's Avatar
psycho dad
Default Cabin Air
Hey Guys,
I'm trying to get some air to blow into the passenger compartment (76 with AC).
The fan motor is blowing at 3 different speeds. I've removed the lower right dash and the duct work.
This door opens and closes and there is some air coming in. It's not very strong and when I attach the duct it dissapates to where you can't really feel it.
I guess there is blockage somewhere, any idea what I should look for?
Old Dec 30, 2018 | 03:01 PM
psycho dad's Avatar
psycho dad
May have found the problem. the lower edge of the heater box is covered in silicone, no bolt. There's got to be an air leak there.
Not sure I want to pull the box now.
Old Dec 30, 2018 | 09:38 PM
kansas123's Avatar
kansas123
Originally Posted by psycho dad
Hey Guys,
Does that door open and close, what does that? Just for my own edification... thanks, it must operate differently than a '72..... Can you fit your hand down there, it might be full of leaves or something?
Old Dec 31, 2018 | 04:30 PM
psycho dad's Avatar
psycho dad
the cable on top pulls it shut when I switch to defrost. I ran a vacuum hose as far as I could from both ends and didn't find anything.
I'm thinking heater box gasket now. With the silicone and mis-matched bolts I'm kinda scared it wont be able to get it back together.
BTW Kansas, I just saw your post for the LED instrument lights and ordered a set. Can't wait to get them in.
Old Dec 31, 2018 | 06:15 PM
BLUE1972's Avatar
BLUE1972
On the last few cars I worked on I found the A/C box full of debris and blocking the sir flow.
If you pull the resister out - you can look in with a scope and see if it's clogged.
Old Dec 31, 2018 | 06:20 PM
kansas123's Avatar
kansas123
You will love those lights
Old Dec 31, 2018 | 08:14 PM
psycho dad's Avatar
psycho dad
I tried that, it was clean
Old Jan 1, 2019 | 10:02 AM
BLUE1972's Avatar
BLUE1972
There is a conversion to use the C4 fan and motor which increases air flow. (a Lot)
C3's - there is a vacuum controlled flap in / by the A pillar under the right fender. This controls the inside air getting pulled into fan.
Old Jan 1, 2019 | 12:46 PM
psycho dad's Avatar
psycho dad
down here by the fan?
Old Jan 1, 2019 | 12:59 PM
BLUE1972's Avatar
BLUE1972
Old Jan 1, 2019 | 01:18 PM
psycho dad's Avatar
psycho dad
ah, thanks. I'll check that out
To Cabin Air
