Bogging down and stalling
Old Jan 26, 2019 | 03:45 PM
68AIR's Avatar
68AIR
Default Bogging down and stalling
Forum: Today I took it for a ride today and towards the end of a 45 minute run it decides to spontaneously bog down and stall as it is idling along in 4th gear. I pulled it over and it restarted. It did it 4 more times and intermittently was running rough for the rest of the way home. It even decided to stall going up the incline for a small bridge so I had to pull it to the side and back down until it cooperated. It did a light backfire through the carb just before stalling and once or twice on the cruise today.. I just restarted back at home and it seems to be idling fine. What are the culprits that I need to look at?
The details: The car has it's original stock 350 with smog pump and points distributor
Old Jan 26, 2019 | 04:07 PM
roboto65's Avatar
roboto65
When did you get gas last, has the carb been rebuilt or cleaned,filter change?
Old Jan 26, 2019 | 08:06 PM
REELAV8R's Avatar
REELAV8R
Many things come to mind fuel starvation? Failing fuel pump, vapor lock?
could be flooding as well, like sinking floats, or junk stuck in the inlet valve.
Did it seem flooded?, and ran fine except for idle?
Old Jan 26, 2019 | 08:14 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
or distributor slipped?
Old Jan 26, 2019 | 09:53 PM
68AIR's Avatar
68AIR
Okay- a tankful ago I had to pump all the gas out of the tank because fuel had gone bad. I replaced the sender (different thread sender not accurate now). I usually always run 100 percent 93 octane but must have screwed up and then compounded the problem by letting it sit to long. It ran good last time out after the replacement fuel added. This time not so much as the trouble began about 30 minutes in to the drive. Carb has not been rebuilt recently. Things on my list for tomorrow include new fuel filter in the Rochester QJ, new condenser, swap out the coil and check the plugs and inside the cap/rotor. So it runs good before the trip and seemed to idle strong once I got back home and it had cooled a bit. After I do this I will report back.
Old Jan 26, 2019 | 10:14 PM
Big2Bird's Avatar
Big2Bird
If you are changing the fuel filter, I would pop the bowl cover and peak. Why not?
Old Jan 27, 2019 | 11:24 AM
68AIR's Avatar
68AIR
What am I looking for in the bowl, sediment, rust, junk? If I do this do I need a rebuild kit for the carb (ie don't you have to unbolt the carb and take out the 5 screws for the air horn assbly for it to come off. I am worried the gasket will need replaced between the top air horn and the bottom float bowl assbly?
Old Jan 27, 2019 | 12:38 PM
Big2Bird's Avatar
Big2Bird
If that bothers you, then do what we did in H.S.
Rev it up to 3000, then cup your hands over the air inlet till it almost stalls. Do this 3 or 4 times. The vacuum will suck all the crap out.
Probably not Lars approved, but I had some good luck with doing it on old cars.
Old Jan 27, 2019 | 01:43 PM
lars's Avatar
lars
The symptoms sound like a fuel starvation problem - the most obvious cause is a partially obstructed fuel filter. The backfire up through the carb is a sign of a lean condition, which will be caused by fuel starvation (plugged filter). Change the in-carb filter and make sure nobody has installed a second, in-line filter in the system. If the symptoms persist after changing the filter, it's time to install a fuel pressure gauge near the carb to check the pressure at the carb inlet when the problem occurs - I can post up a photo of a setup you can use to check this.
Lars
Old Jan 27, 2019 | 02:28 PM
71 Green 454's Avatar
71 Green 454
Wow lars, I'm always amazed at how quick and helpful you are for fellow CF members.
To Bogging down and stalling
