75 Vette suspension question
Old Jan 27, 2019 | 04:12 PM
buzz2none's Avatar
buzz2none
Default 75 Vette suspension question
I am a novice looking at purchasing a 75 Vette. I noticed that the front end appears to sit higher than the rear. What could be causing this and how expensive/difficult to correct? Thanks ahead of time for your insight.
Old Jan 27, 2019 | 04:16 PM
'75's Avatar
'75
It's possible the rear spring is worn out and needs replaced. Front and rear measurements will tell if the front is high or the rear is low.
Old Jan 27, 2019 | 04:39 PM
buzz2none's Avatar
buzz2none
This is an image of the vehicle
Old Jan 27, 2019 | 05:20 PM
'75's Avatar
'75
Rear looks ok, but the front sure is high. Is it an AC car with compressor removed? May have had front end work and the springs are not indexed correctly.
Old Jan 27, 2019 | 05:21 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
looks deceive.
measure
Old Jan 27, 2019 | 05:27 PM
buzz2none's Avatar
buzz2none
How do I go about getting decisive measurement?
Old Jan 27, 2019 | 05:31 PM
'75's Avatar
'75
Tape measure from the highest point of the fender opening to the ground on all 4.
Old Jan 27, 2019 | 05:45 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
decisive would be per gm specs and measuring points.
general would be the wheel arch as mentioned.
too me, late model C3s with standard 225/70 tires had a little too much
gap from wheel arch to tire.
and yes sometimes the azz looks lower.
combo of car lines and tire gap.
a measure of around 27 inches from ground to wheel arch is in the ball park.
Old Jan 27, 2019 | 06:49 PM
DUB's Avatar
DUB
I agree... due your photo of the car was not taken in the sunlight. And when I copied it and tried to enlarge it...I could not....and what you want is the rear to be about 1 inch higher than the front...and 27" at the center of the FRONT wheel well lip is a good starting point.
DUB
Old Jan 27, 2019 | 07:23 PM
derekderek's Avatar
derekderek
Would shorter rear spring bolts help as an interim fix?
Old Jan 27, 2019 | 08:05 PM
stumpshot's Avatar
stumpshot
I have a combination of aluminum heads and intake and the AC is removed. I also have a high front end until I get time to cut a coil.
Is the engine stock?
Old Jan 27, 2019 | 08:50 PM
speedreed8's Avatar
speedreed8
Gas tank may be full too. Helping to lower the rear.
Old Jan 28, 2019 | 06:07 PM
DUB's Avatar
DUB
So much is going to depend on how high the front is currently if adn when teh owner gets back with that measurement.....and by the looks of it....it is higher than normal and not so much the rear is too low.
DUB
Old Jan 28, 2019 | 07:21 PM
GUSTO14's Avatar
GUSTO14
I would first ask the seller for an explanation of why the front end seems to be so high.
If he says he has no idea, I would ask him if any work has been done on the front end since he has owned it? Ask if someone installed some other than stock springs to lift the front end? Turn the wheels to full lock in one direction and look in at the springs to see if someone has inserted some wedges in them to lift it. (A very common practice back in the day to compensate for sagging springs.)
If work has been done on the front end where the springs were removed either to perform the work, or to replace them, it's possible that they did not get them seated in the lower pocket correctly which can result in it appearing that the front end has been lifted.
All else being okay and with no other explanation, the springs should be able to be changed out for less than $200 by a competent mechanic for the correct ones.
Good luck... GUSTO
Old Jan 29, 2019 | 10:31 AM
The Punisher's Avatar
The Punisher
I agree worn out spring or some weight taken off that motor. intake. a/c compressor,etc.
Old Jan 30, 2019 | 12:53 PM
buzz2none's Avatar
buzz2none
To everyone that has weighed in I appreciate your insights. This vehicle was acquired by the current owner in lieu of payment for work performed. He is selling due to lack of space and interest in the vehicle. He admits to having not a whole lot of knowledge on the car or its history.
Old Jan 30, 2019 | 03:10 PM
The Punisher
Well do your homework first before purchasing it. Lots of information on the forum.
Old Jan 30, 2019 | 03:57 PM
HeadsU.P.'s Avatar
HeadsU.P.
One other thought on a too big of gap above the front tire. As others have mentioned the end of spring has to be clocked into a pocket or else . . . .
And, I wonder if those are BBC springs instead of SBC springs. I believe there are two sets available during the yrs that offered the Big Block (heavier).
To 75 Vette suspension question
