Is This Normal Trailing Arm Movement ?
Old Jan 31, 2019 | 10:05 AM
danc24's Avatar
danc24
Default Is This Normal Trailing Arm Movement ?
I'm getting ready to drop my diff to investigate excessive stub axle play, so I've removed the leaf spring, half-shafts and strut rods. So the only thing still attached to the trailing arm is the shock. With the alignment shims still in, should I be able to move the trailing arm this much? Bushings look original.
Old Jan 31, 2019 | 10:20 AM
gkull's Avatar
gkull
Time to replace them with poly bushings and stainless steel shims
Old Jan 31, 2019 | 11:27 AM
Big2Bird's Avatar
Big2Bird
Yes, they are toast.
Old Jan 31, 2019 | 11:31 AM
Big2Bird's Avatar
Big2Bird
George, my entire car is poly, but the T/A bushings are the only ones I would change back to rubber or Johnny Joints. The poly just doesn't have the needed compliance for that application. IMHO.
Old Jan 31, 2019 | 11:39 AM
danc24's Avatar
danc24
Thanks guys! Just so I know, how much lateral movement should I expect if the rubber bushings are good?
Old Jan 31, 2019 | 12:40 PM
gkull's Avatar
gkull
I'm on my 3rd set of trailing arm rebuilds. started out with stock 79 and replaced them with poly HD trailing arms with HD outer spindles. Then I did another set of poly swing arm bushings. I do live in low humidity desert where nothing rusts away. I have everything solid or poly except for the body to frame mounts.
Old Feb 1, 2019 | 08:50 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
If poly bushings are the bushing of choice over rubber in the off-road world where those vehicles are severly punished, then poly works just fine anywhere they are installed in our C3's, imho.
Old Feb 1, 2019 | 05:58 PM
flyeri's Avatar
flyeri
Those need replacing regardless of the material you choose. Mine did not move that much or anywhere close to that. Ne bushings made a different car out of it. I used rubber for what it's worth.
Old Feb 1, 2019 | 06:05 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by flyeri
Those need replacing regardless of the material you choose. Mine did not move that much or anywhere close to that. New bushings made a different car out of it..
To Is This Normal Trailing Arm Movement ?
