I saw this in another post and wanted to ask if someone knows what kind of fuse item #4 is. (As the book say's Breaker ASM) I currently have a glass fuse in my fuse block.
Your local parts store should be able to get one for you.. And from that AIM page-- that breaker is for the power windows. The headlight breaker is built into the headlight switch..
75 vette - Do you think that would cause my power windows not to work using a glass fuse instead of the breaker. Both windows will not work - Both windows Motors are good already tested them.
It is hard to say becasue you might have dirty terminals in your fuse panel so even though you install a fuse or circuit breaker...UNLESS you go in and check the TERMINALS to make sure they have power on them with a voltmeter...there is no way in telling if you are gettign 12 volts to the RELAY.
SO....even though you get the correct circuit breaker...you still ahve a relay that is used to make your window motors work.
