Removing pilot bearing
Old Feb 6, 2019 | 07:12 PM
CiCiC3's Avatar
CiCiC3
Default Removing pilot bearing
I have a 74 I want to remove the pilot bearing/bushing. I think I remember filling the bearing with grease and then pounding an equal size socket wrench into the grease to squirt it out. Is that how it works? It's been a while. Thanks for any new tips on that if you have any.
Old Feb 6, 2019 | 08:09 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
yes that will work. I had an old clutch index I used. Use what ever tool slides easily through the hole, it doesnt need to be tight, just fill the hole. Test fit it before packing in the grease.
Then pack it and tap the tool in. Pull it back out, repack the hole, and do it again. If you use a socket, I would put it in head first so that it acts more like a piston and use a deep socket so you can get it back out. if you can use an extension to fill the square drive hole.
They make a puller but I would try the grease first, its alot cheaper and works pretty well
Old Feb 6, 2019 | 08:20 PM
croaker's Avatar
croaker
I’ve used the grease method before but last time I used a tap and bolt. Worked well after I couldn’t get the hydraulic grease method to work.
Old Feb 6, 2019 | 08:43 PM
Frankenvette's Avatar
Frankenvette
I used the bread method. I kid you not, check you tube video's on this. You pack white bread and eventually it will push out the pilot bushing. No mess like grease will leave behind. I was truly surprised it worked but there you go.
Old Feb 6, 2019 | 08:46 PM
drwet's Avatar
drwet
I have an old input shaft that I use. Hasn't let me down yet. I still remember the first time I tried it about 40 years ago, and thinking "This is ridiculous, this can't work." But it does.
Old Feb 6, 2019 | 10:04 PM
69ttop502's Avatar
69ttop502
I just thread a, I believe 5/8 inch bolt into the bushing. Didn’t even use a tap as the bushing material is so soft. As soon as the bolt bottoms in the crank, the bushing turns out. Two minutes and no mess.
Old Feb 6, 2019 | 10:33 PM
1974ta's Avatar
1974ta
I used play dough. Worked without the mess.
Bill
Old Feb 7, 2019 | 05:56 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
I used the coloured modeling clay and it is also good for checking the hood clearance from air filter as well .
Old Feb 7, 2019 | 11:26 AM
stingr69's Avatar
stingr69
Grease and a wooden dowell. Need to wrap some masking tape around the stick diameter to get it snug in the bore.
Old Feb 7, 2019 | 04:09 PM
CiCiC3's Avatar
CiCiC3
I think I'll give that method a try. Using bread did not work for me. Still messing with this, Thanks
Old Feb 7, 2019 | 04:24 PM
croaker's Avatar
croaker
This is what I did but used a tap I thought it was 5/8 wasn’t sure. Didn’t want to misinform the size.
Old Feb 7, 2019 | 05:50 PM
69ttop502's Avatar
69ttop502
Never has it not worked for me. Just use long enough bolt to reach the crank. If your bushing is the oil lite you won’t need a tap. If it is magnetic, you might need to tap it first.
Old Feb 8, 2019 | 01:24 PM
CiCiC3's Avatar
CiCiC3
I think it started to work but the bolt material was too soft and the bearings popped out. I can use it for the driver now and fill with grease after I buy some. That's the only reason I have not tried the grease method yet.
Old Feb 8, 2019 | 01:37 PM
69ttop502's Avatar
69ttop502
Oh shoot, I didn’t realize you had a bearing. Sorry I thought you had a bushing!
Old Feb 8, 2019 | 02:20 PM
stingr69's Avatar
stingr69
I doubt the grease method will ever work with a bearing. Only works on the bushing.
Time to chisel it out I guess.
Old Feb 8, 2019 | 07:12 PM
CiCiC3's Avatar
CiCiC3
I'll take your word that it won't work, what about swapping out all the needle bearings repack it with grease and call it good?
Old Feb 8, 2019 | 07:30 PM
stingr69's Avatar
stingr69
Nope. Time to remove it and replace it with a proper bushing.
To Removing pilot bearing
Old Feb 8, 2019 | 08:47 PM
71 Vert LS1's Avatar
71 Vert LS1
Time to grind a hook into a piece of 1/2 round stock and hook the inside of the bearing race. Make it long enough so you can clamp a vise grip onto the 1/2' round stock and slowly tap it out.
Old Feb 8, 2019 | 08:57 PM
carriljc's Avatar
carriljc
You can try one of these from autozone... free to borrow. Didn't work for me (just last year), but they are available. I ended up chiseling mine out (again). Chiseling it out is rather easy anyway -- just takes a little longer.
https://www.autozone.com/loan-a-tool...ype/470423_0_0
Old Feb 8, 2019 | 11:36 PM
lars's Avatar
lars
I've never had the grease & hammer method work. I use a real pilot bushing removal tool, and it has never failed to draw the bushing out simply and easily. No problem.
Lars
