Electrical connector?
Old Feb 19, 2019 | 11:58 AM
DAD111's Avatar
DAD111
Default Electrical connector?
75 corvette - down to the last connector that needs a home - Can not find what plugs into this. Wire Diagram not much help. It is going to the horns. Horns do work
Old Feb 19, 2019 | 11:59 AM
DAD111's Avatar
DAD111
Another picture
Old Feb 19, 2019 | 12:07 PM
Peterbuilt's Avatar
Peterbuilt
I'll take a guess.
Could it bring power to the hood air door solenoid?
Old Feb 19, 2019 | 12:23 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The connector with the white paint on it and the red to green splice is probably for the horn. Green is usually the horn.
Old Feb 19, 2019 | 12:26 PM
DAD111's Avatar
DAD111
Yuup green is going to the horn and horn blows - Its the tan and black wire connector that im not sure of.
Old Feb 19, 2019 | 12:29 PM
Peterbuilt's Avatar
Peterbuilt
https://docs.google.com/viewer?a=v&p...WRiNTdjNjdkNTQ
Old Feb 19, 2019 | 12:50 PM
DAD111's Avatar
DAD111
Thanks Peterbuilt - I see it now, hood air door solenoid
Not related - Again no motor in car as of yet - I pulled up on the headlight buckets last night to pop them up by hand - Both came up as should, I can push the drivers side back down but the pass side will not go back down. Any ideas how to get that light bucket back down.
Old Feb 19, 2019 | 01:20 PM
Peterbuilt's Avatar
Peterbuilt
You have to pull it down from the bottom.
Pull down on the 'actuator link bracket' and be careful not to break the little headlight warning switch (#8)
Old Feb 20, 2019 | 12:11 PM
DAD111's Avatar
DAD111
Easy fix - pulled down on the 'actuator link bracket' and the light came down. I found another wire connector that was all taped up. It is off of blower motor/ heater element wire harness pass side -engine compartment.
Old Feb 20, 2019 | 12:12 PM
DAD111's Avatar
DAD111
Old Feb 20, 2019 | 07:43 PM
TimAT's Avatar
TimAT
MAybe the superheat switch on the A/C Compressor? The other connector looks like the thermal limiter fuse they had then.
Old Feb 20, 2019 | 09:48 PM
'75's Avatar
'75
The one with the jumper goes to the A6 compressor, the other plug goes to the pressure switch on the liquid line inside the right fender lip.
Old Feb 21, 2019 | 08:35 AM
DAD111's Avatar
DAD111
Thanks Guy's - So these are for the A/C - Im not hooking up the A/C as of now ( Down the road some time) So safe to say - Keep the jumper wire in the plug and seal tape that pigtail back up until further use?
Old Feb 21, 2019 | 07:07 PM
'75's Avatar
'75
The jumper is not needed and should not be there.
Old Feb 25, 2019 | 11:48 AM
DAD111's Avatar
DAD111
I have another question - Finally i have the motor in the car over the weekend and wires hooked up to the starter and Alt - New starter , All the lights work etc. When i turn the key to start i hear a click at the starter interlock relay on firewall but no start. Just like if the battery was dead. Battery new - 12 volts and charged. So i looked into the seat belt crap. This car has a new wire harness without the seat belt thing + It has brand new seats without the seat belt switch. The only harness that has not been replaced is this one with blower motor and relay. Been reading how to bypass, but to bypass its always under the seats. So Question how do i bypass the relay on the firewall. A few pics of what i have.
Old Feb 25, 2019 | 11:50 AM
DAD111's Avatar
DAD111
Old Feb 25, 2019 | 11:51 AM
DAD111's Avatar
DAD111
To Electrical connector?
Old Feb 25, 2019 | 01:40 PM
Peterbuilt's Avatar
Peterbuilt
Yours is not the stock relay.
The stock can be bypassed like this:
Old Feb 25, 2019 | 01:55 PM
DAD111's Avatar
DAD111
Peterbuilt do you think that could be the blower motor Relay that i am posting.
Old Feb 25, 2019 | 02:33 PM
Peterbuilt's Avatar
Peterbuilt
Yes!
On my '74 the 'starter interlock relay is mounted to an orange base on the firewall.
