Engine identification
Old Nov 2, 2002 | 11:09 AM
brimcc's Avatar
brimcc
Default Engine identification
Can someone tell me what theses engines and heads are out of?
Both have same block 3970010
462624 heads
V 0913TYZ
168497194
V 0518CKX
and 338882 heads recent value job for $100
Decisions, dicisions
Old Nov 2, 2002 | 11:40 AM
Paul L's Avatar
Paul L
Default Re: Engine identification (brimcc)
This is an interesting site to search.
http://www.mortec.com/
Old Nov 2, 2002 | 11:51 AM
no_radio's Avatar
no_radio
CKX is either:
'72 Corvette 350, 200HP, 4BBL, TH400
or
'73 Camaro 350, 145HP, 2BBL, California Emission, automatic trans
or
'76 Corvette 350, 180HP, 4BBL, TH350
TYZ is either:
'75 Truck 350, 160HP, 4BBL, automatic
'76-'77 Truck 350, 165HP, 4BBL, automatic
882 heads are about the best flowing "smog" era heads, according to flow tests by Chevy High Performance magazine. They can have either 2.02" or 1.94" intake valves from the factory. They were used on Corvettes from at least '73 (maybe earlier) through most of the '70s I believe. Not bad heads, but not ultra super performance heads either. They do seem to respond to mild port work (bowl blend, etc) pretty well, I have them on my '74 and it is quite a handful with the cam, etc that I am using.
I'd go for one that is 4-bolt main, if possible. Also, see if you can measure the cylinder diameter to make sure it hasn't already been maxed out on bore. Otherwise, pick the one that seems to be in the best condition I guess.
Jeff
Old Nov 2, 2002 | 05:37 PM
brimcc's Avatar
brimcc
Default Re: Engine identification (no_radio)
Will the heads 338882 work with a street cam and give me respectable HP?
To Engine identification
