Tach filter revisited
Old Nov 2, 2002 | 12:06 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Tach filter revisited
Hope this topic hasn't been worn out. :smash: I finally got a chance to look at my '76 Vette's tach filter...anticipating making one as per the schematic I found somewhere on this forum.
When I looked at the schematic, it showed an IN and an OUT then a ground. Looking at what is on my car, is just a round cylinder shaped deal with a single lead .. and there is just one connector in the harness that goes to it. :yesnod:
I have a reasonable amount of techie experience :blueangel: and I've used a soldering iron a few hundred times but what the heck am I missing here???? :confused: :mad :confused: :mad :confused:
Old Nov 2, 2002 | 12:26 PM
Paul L's Avatar
Paul L
Default Re: Tach filter revisited (SanDiegoPaul)
One end of the brown wire goes into the wiring harness (as shown) and the other to the "tach" connector on the distributor cap.
Old Nov 2, 2002 | 01:20 PM
SanDiegoPaul
Default Re: Tach filter revisited (paul79)
I see. I thunk :hat that the tach lead that is on the distributor NOW was going to the dash.
Old Nov 3, 2002 | 12:58 AM
Schmucker's Avatar
Schmucker
Yeah, I need one of them also, but it can wait. My tach isn't too jumpy. I don't need exact tach readout. Bouncing from 5500rpm to 6000rpm isn't that big of a deal. If I did it though, I'd probably make my own IC and stick it in a plastic box.
Old Nov 3, 2002 | 01:06 AM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Paul,
It sounds like you are describing a RF noise filter capacitor. They look a lot like the old condenser/capacitor that was in points type ignition systems. On the earlier C-3's there were several of them on the car to cut down on electrical interference (mainly AM) on the radio. There is one on the heater/AC blower as well as the ignition.
Paul's picture really shows what a factory correct tachfilter should look like.
Old Nov 3, 2002 | 09:20 AM
Paul L's Avatar
Paul L
Default Re: Tach filter revisited (Smokehouse69)
I guess that I am lucky that mine is still working. I did a parts search at work on those units. They are GM-discontinued, of course, but they were not just a Corvette item. They appeared on all mid-to-late 1970s GM vehicles with HEI and a tach. So check the the salvage yards for Camaros, Firebirds, etc.
Old Nov 3, 2002 | 10:57 AM
SanDiegoPaul
I looked at mine closer and it does have two leads ... my bad! But neither of them go to the tach connection on the HEI. Rearranging the wiring didn't change things a single bit.
The tach still hovers at 1250RPM day or night rain or shine. It does however, quiver when I turn the key on or shut off. :smash: :smash:
Old Nov 3, 2002 | 09:48 PM
Fleetwood's Avatar
Fleetwood
It sounds like it could be the printed circuit board on the back of the tach that could be faulty.
Old Nov 3, 2002 | 09:51 PM
Paul L's Avatar
Paul L
Default Re: Tach filter revisited (Fleetwood)
I agree. If the tach is stuck, it is not the filter.
Old Nov 3, 2002 | 10:28 PM
SanDiegoPaul
Problem is, that it doesn't LOOK LIKE the tach gauge is stuck! It moves a bit when the key is turned on. And the way it bounces, it looks free not stuck or sticking.
I KNOW what it REALLY is though: Frustrating! :smash: :smash: :seeya
To Tach filter revisited
