Wheels/Tires Question
Old Mar 9, 2019 | 06:29 PM
x IRON EAGLE's Avatar
x IRON EAGLE
Default Wheels/Tires Question
Looking at getting a cheap set of rallys that I can powder coat black. Will these fit? (76' with stock suspension) https://www.jegs.com/i/JEGS+Performa...iABEgL3GfD_BwE. Also, what are the widest tires I can fit in the front and rear? Thanks as always.
Old Mar 10, 2019 | 09:37 AM
3JsVette's Avatar
3JsVette
No they are the wrong bolt pattern. You need 5 on 4.75. They are 5 on 5.
The factory 15X8 has a 4" backspace. The 1/4" difference is not a deal breaker.
Tire size from the factory starting in 1978 was 255/60-15. The front fenders had to be "trimmed" in the front leading edge and rear corner at the rocker for clearance,
Look at a '78 Pace Car to see what I'm talking about.
Old Mar 10, 2019 | 11:30 AM
x IRON EAGLE
How about this set? What would be involved with making them work? https://www.jegs.com/i/Year-One-Whee...RWSD1/10002/-1
Old Mar 10, 2019 | 11:31 AM
OldCarBum's Avatar
OldCarBum
I’ve seen numerous sets of OEM rallies wheels for sale on the forum which are the correct wheel size and back spacing and usually come with the rings and center caps.
There are several manufacturers who rallies in the correct size and some are available in black.
The rings and center caps are also available through several forum vendors.
Show us pictures of your finished product.
Old Mar 10, 2019 | 12:18 PM
3JsVette's Avatar
3JsVette
Yes they should work even though the backspace is not ideal. There are C3s on the forum using that size with that backspace and either a 245/50-17 or a 255/50-17 tire. You also have to realize these cars are not all created equal due to age, accidents, wear and tear. So what just fits on one may rub on another.
IMCO take the advice from OldCarBum and purchased an OEM set of take offs. At least the size and backspace is correct. Of course that's if you're not looking to upgrade a 17" high performance tire.
Old Mar 10, 2019 | 12:50 PM
x IRON EAGLE
Thanks alot everyone I'm just trying to get some ideas together now. I can't decide what size and style to go with but this is sage advice from all of you that I will definitely apply to my search.
Old Mar 10, 2019 | 02:04 PM
Bikespace's Avatar
Bikespace
Are you looking for a set of 15" track wheels, or every day wheels? You can find YJ8 (or N90) aluminum wheels on Craigslist all the time. They'll be lighter than the steel wheels, are (almost) correct for your car, are 15"x8", have the correct backspace and bolt pattern, and would look good both with black plasti-dip, or in stock polished aluminum.
If you go to bigger wheels, try to go to 18". The performance tire selection is likely to last longer in that size. Perhaps you've seen these, a number of forum members use them. http://www.etmags.com/lt_iii.html
Old Mar 10, 2019 | 03:04 PM
x IRON EAGLE
My original plan was to get a set of 15 inch rallys and have everything powdercoated black. I want to go for the look of Jimmie Johnson's resto-mod but now I'm wondering if I should go up in wheel size. They would be for everyday/show use.
To Wheels/Tires Question
