MSD Ignition
Old Mar 14, 2019 | 09:48 PM
Red Hot 71's Avatar
Red Hot 71
Default MSD Ignition
Have a 71 Corvette w/MSD ignition. Just finished header side pipe install & while checking out exhaust sound, revved motor a couple of times for tone & engine just quit. I do not appear to have any spark. Can an MSD box just die? I did not run the car long enough to build up any kind of heat. Looking for recommendations on where to start. That MSD 6A box is pretty pricey to just parts change. Any help would be appreciated as warm weather is upon us here in NC.
Old Mar 14, 2019 | 09:55 PM
Big2Bird's Avatar
Big2Bird
Yes, they can just die. I have tester here.
I suggest going to MSD.com, and look up their trouble shooting tech papers.
It can be either the coil or the box or even both.
Then call MSD and raise some...........................
Old Mar 15, 2019 | 08:49 PM
mrvette's Avatar
mrvette
My MSD failed on me too, did not last long and too boot I put it under the dash, not in the engine heat....
my only operational comment is that it made no difference compared to a stock HEI......
Old Mar 15, 2019 | 11:49 PM
cabman72's Avatar
cabman72
Is the red light on the MSD box lit when the key is on. Maybe the red "hot" wire has a loose connection or maybe a blown fuse.
Old Mar 16, 2019 | 09:36 PM
Red Hot 71's Avatar
Red Hot 71
Thanks for the input guys. Wire going to the distributer was loose. Must have been from vibration. Thanks again!
To MSD Ignition
