Engine stand
Old Nov 3, 2002 | 04:17 AM
Lasse's Avatar
Lasse
Default Engine stand
I gonna buy an engine stand for my 454 and the engine stand that I've found takes max 450 kg. How much does it weight with iron heads?¨ :cheers:
[Modified by Lasse, 9:31 AM 11/3/2002]
Old Nov 3, 2002 | 06:03 AM
BB wowbagger's Avatar
BB wowbagger
Default Re: Engine stand (Lasse)
I bought my engine stand at Biltema,and it holds a complete bigblock..I belive theres two diffrent sizes of stands so pick the biggest one,that holds for 450Kg.. :cheers:
PS:Lasse,du har inga rullvippor som ligger och skrotar i någon låda?:DS
:cheers:
Old Nov 3, 2002 | 08:12 AM
Lasse's Avatar
Lasse
Default Re: Engine stand (BB wowbagger)
Great, that was Biltemas I thought of!
Tyvärr, de som jag har ska i igen.. Om jag inte bestämmer mej för att ta in en ny motor från USA. Men i så fall kan jag höra av mej.
:cheers:
Old Nov 3, 2002 | 08:36 AM
zwede's Avatar
zwede
Not even an all iron BB will reach 450kg, so you'll be OK. From hazy memory I believe a fully dressed all iron BB is in the 700 lbs range, which is about 320-360 kg or so.
Of course some aluminum heads, intake, w-pump etc never hurts! :)
To Engine stand
