Intake choke tube
Old Mar 24, 2019 | 05:48 PM
fake's Avatar
fake
Default Intake choke tube
The choke tube that attaches to the manifold does it need a gasket? Can the choke tubes be cleaned?
Old Mar 24, 2019 | 06:15 PM
lars's Avatar
lars
Assuming you're talking about a 1975 - 1979 Q-Jet hot air choke tube, there are no seals around the tubes where they insert into the manifold heat exchanger - they just slip in metal-on-metal. Yes, you can use a wire to clean out the tubes, but they should not be plugged with anything: Only clean air from the air cleaner air horn area is drawn through those tubes.
Lars
