Carb question
Old Nov 3, 2002 | 07:58 PM
John D.'s Avatar
John D.
Default Carb question
My 71 350 has a Quadrajet carb that says Carter made for GM.
Number on it are 7047200 with this below C1 Fa.
Is this the corrct carb for my car??????
Old Nov 3, 2002 | 08:11 PM
73 LS-4's Avatar
73 LS-4
Default Re: Carb question (John D.)
Unfortunately no, your proper number would be 7041213 (270hp/manual trans) according to the black book.
:cheers:
Pat Kunz
Old Nov 4, 2002 | 03:40 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
that can not be the right number on the carb because a 7047200 is a 2 barrel for a 72 pontiac :chevy
Old Nov 4, 2002 | 08:12 AM
FERL 73's Avatar
FERL 73
Here's a link to decode. This link won't tell you what is correct for your car but it can decode your number. Are you sure the second 7 isn't a 1? http://www.carbs.net/quadnumber.htm
Old Nov 4, 2002 | 08:35 AM
John D.'s Avatar
John D.
Default Re: Carb question (FERL 73)
Thanks for getting back to me. I will check the second 7 my eyes have trouble with small numbers I will look to se if it is a 1
Thanks, John. :chevy :seeya
Old Nov 4, 2002 | 11:06 AM
PRNDL's Avatar
PRNDL
7041200 would be so much better!! (better than a 2bbl for a 72 pontiac!! :lol: ) 7041200 is listed for several 71 Chevy bigblock applications in 71, with automatic trans...
see this site:
http://www.blake.com/oemcarbs/chevy2.htm
Old Nov 4, 2002 | 12:40 PM
lars's Avatar
lars
Carter built Q-Jets for GM under license from Rochester, so you can have a Carter Q-Jet and be "correct." However, a 7041200 is not a SB Vette carb - it is a Q-Jet for a 1971 402 or 454 Chevelle with auto trans. It should be jetted with #77 jets, #49 primary rods, and "BG" secondary rods. It will run just fine on your Vette if it's set up to the stock specs.
Old Nov 4, 2002 | 02:07 PM
John D.'s Avatar
John D.
Thanks to all for all the advice and references. :chevy :seeya
To Carb question
