So had my car out for the first time yesterday and got on it a bit. Noticed it didn’t seem to have enough go. Tonight I started checking and it looks like I’m not getting WOT with the pedal.
Linkage at carb works fine fine but stepping on the pedal and watching and I can see it’s not moving enough.
So is there a quick fix? Can the cable stretch that much? Searched a little. It doesn’t seem like there is any adjustment?
Didnt have ave a chance to look much further but hoping to tomorrow night
Cable or linkage? Some guys put a bend in them or fab one up with stuff from Summit, Speedway motors etc.
Do you have someone who can floor it while you check to see how much travel is left @ the carb?:
I hate to say this but....Add a zip tie to take up the slack (Assuming you have some) where the cable connects to the gas pedal. If it helps you know where the problem is.
Most problems like this are due to some issue with the accelerator pedal mechanism. Some get bent from years of use; some have problems where the cable connects to the pedal mechanism; some are just 'worn out'. But, ALL can be adjusted or repaired with a little ingenuity. Investigate the details of pedal and cable from foot to the carb. If you can't get full throttle travel with normal adjustment method (at cable connection to carb), and the cable is the correct piece for your car, the problem is in the pedal area.
2016 C3 of Year Finalist
I did the zip tie trick to find out how much travel I was getting , the I pulled my throttle pedal and bent the arm to get more travel. I get full throw now. You should look and see which hike you are in on the linkage as well. Closer to the shaft is more pull for less pedal movement. further out needs more pedal movement. And as mentioned, make sure your floor mat isnt up under the pedal too
Here is a list of issues that will prevent full throttle travel - from my Q-Jet paper available upon e-mail request:
A common problem is the issue of inadequate throttle cable travel. This is very common on Corvettes and Camaros. With a helper in the car and with the engine “off,” have the helper fully depress the gas pedal (with the engine hot and the choke wide open to assure that the lockout lever is disengaged). Observe the carb on the driver’s side and see if the secondary throttle moves to the wide open position: You can grab the throttle lever once the assistant has the pedal to the floor and see if you can move it further. If the gas pedal does not fully open the secondary throttle, you have one of several methods to fix this:
Remove your floor mat. I call this the “25 horsepower floor mat tuning trick.”
Install the throttle cable in the correct position on the throttle lever. The Q-Jet has an “upper” and a “lower” cable attach hole: The upper hole was used for trucks and station wagons. The lower hole was used for Corvettes, Camaros and Novas. If you install a Corvette throttle cable in the upper hole, you will never achieve wide open throttle since there is not enough cable travel to open the throttle from the top lever location.
Straighten your throttle cable attach bracket. The bracket that supports the cable at the carb is often bent slightly forward. If the bracket is bent or moved forward, it will not allow enough cable travel to open the throttle fully. Simply bend the bracket back just a tad: I use a big hammer and a steel rod to give it a whack. I call this the “25 horsepower hammer tuning trick.”
Fix your gas pedal linkage. Very often, the actual steel linkage coming off your gas pedal will be bent a little “flat.” This will cause the pedal to hit the floor before the carb is wide open. You can give the pedal more travel by simply grabbing the gas pedal and bending it up off the floor. Care should be taken not to damage any plastic pedal rod bushings when doing this: Support the plastic pivot points when bending the pedal rod so the plastic bushings do not break.
Fix the slop in the gas pedal attach lever. Many C3 Corvettes have a bit of wear on the lever that attaches to the gas pedal rod: The rod is "D" shaped, and the attach lever has a "D" hole with a screw tightening feature. If this "D" hole is worn, you can remove the lever, grind some material off the locking feature surfaces so it snugs up tighter, and re-install it to gain some travel
so got a chance to work on it a bit last night. the issue definitely seemed to be at the pedal. heres the interesting thing, I guess early 68 has a different gas pedal
Yes that's an early 68 pedal. If you have to bend anything, I took mine out of the car and bent mine on the metal rod at the bend near the pedal. Be careful not to brake the plastic hinge. I just hooked mine up last night and the difference between the 2 holes is significant in how much throw you get
I had #5 from Lars's list. The bolt/clamp connection between the pedal and the D-rod was loose, and the slop was right there. Pedal was getting WOT when floored due to this extra slop at the start of pedal push. Tightened that up, found WOT, secondaries woke up, and re-gained my Hyper-Drive!
I must have posted this 4 or 5 times already, but I love sharing this one!
Love those cheap fixes!
Lars... should my throttle linkage be on the lower hole (where the spring is attached)? This is my '68 with a 427 (not original carb). My kick down is not hitting the switch above the gas pedal (previous owner has a tube on it, but still short of moving the switch).
