Headlight issue .....1982
Old Apr 15, 2019 | 02:39 AM
Brack c's Avatar
Brack c
Default Headlight issue .....1982
Long story short .... low beams quit working so I assumed my dimmer switch went bad . Installed new switch & all 4 lights come on , doesn't matter if it's on Hi beams or low .
Anyone come across this issue before ...
Old Apr 15, 2019 | 09:06 AM
henrikse's Avatar
henrikse
Sounds like a bad switch. All 4 should be on for high. When you step on dimmer do you hear a click? Use a test light and test for voltage at the switch
Old Apr 15, 2019 | 10:26 AM
Gunfighter13's Avatar
Gunfighter13
Your Hi-Low beam is on the turn signal switch using the lever. make sure you replaced the correct switch and connected it right.
Hi-Low beam switch
https://www.rockauto.com/en/moreinfo...041185&jsn=471
Turn switch
https://www.rockauto.com/en/moreinfo...041185&jsn=481
Don't forget to adjust the switch (correct rod and lever adjustment)
Old Apr 15, 2019 | 12:21 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
^^^THIS^^^ There isn't a floor switch in an 82 for high beams, like mentioned it's in the turn signal lever when pulled back. Low beams come on with headlight switch pulled on dash.
Old Apr 15, 2019 | 04:21 PM
Brack c's Avatar
Brack c
Yes , it's the switch on steering column , I replaced it with new and still all 4 come on..no matter if switch is pressed or not
Old Apr 15, 2019 | 04:27 PM
Buccaneer's Avatar
Buccaneer
Do you have cruise control on your turn signal lever? If you do, where did you get the 82 replacement?
Old Apr 16, 2019 | 12:23 AM
Brack c's Avatar
Brack c
Yes
I have cruise control on it & I bought the dimmer switch at the local O'Reillys ...looks identical as the original one
To Headlight issue .....1982
